  2. Functional Verification
  3. SV: How to name an unnamed block
  • Subscribers 69
  • Views 29883
SysTom
SysTom over 9 years ago
If I create a variable in a for-loop:
    for(int i=0;i<N;i++) begin...
It creates and unnamed block.  If you $display("%m") in the block it is called "...unmblkX" where is an integer.
If I try to name the block (as allowed in Modelsim)
    for(int i=0;i<N;i++) begin : my_block...
The behavior does not change.  How can I name an unnamed block?
  • StephenH
    StephenH over 9 years ago
    Hi Tom.
    What version of the software are you using, and can you share a runnable example that demonstrates the incorrect behaviour?
    I ran this code and got the answer I'd expect: all the block names are reported exactly as desired.
    module my_tb;
    initial
    begin : my_initial_block
    int i;
    for (i=0;i<1;i++) begin : my_for_block
    $display("%m");
    end : my_for_block
    end : my_initial_block
    endmodule
    bash-4.1$ xrun named_block.sv -q
    xcelium> run
    my_tb.my_initial_block.my_for_block
    xmsim: *W,RNQUIE: Simulation is complete.
    xcelium> exit
  • TAM1
    TAM1 over 9 years ago
    The behavior does change if you move the declaration of the index 'i' into the for loop itself. That is because a local variable declared in a for loop creates its own SystemVerilog scope.
    module my_tb;
      initial
        for (int i=0;i<1;i++) begin : my_for_block
          $display("%m");
        end : my_for_block
    endmodule
    This has the output: my_tb.my_initial_block.unmblk1.my_for_block
    But you can label the for-loop itself. This is probably what you want to do.
    module my_tb;
      initial
        for_loop: for (int i=0;i<1;i++) begin : my_for_block
          $display("%m");
        end : my_for_block
    endmodule
    This has the output: my_tb.my_initial_block.for_loop.my_for_block
  • SysTom
    irun 15.10-s008
  • SysTom
    Thanks TAM1 - I did not know about that. Learn something everyday. Thanks again, Tom
  • Sarah Bishop
    Sarah Bishop over 9 years ago
    I found a guide like this:
    ;make an anonymous block
    ;arguments: selection set, insert point, name - typically ""
    ;source unknown
    (defun makeblock (sset baspoint name / i e en blocktype)
    (if sset nil (setq sset (ssadd)))
    (if (or (/= 'STR (type name)) (= "" name)) (setq name "*A"))
    (if (= (substr name 1 1) "*")
    (setq blocktype 1 name "*A")
    (setq blocktype 0)
    (entmake (append
    '((0 . "BLOCK"))
    (list (cons 2 name))
    (list (cons 70 blocktype))
    (list (cons 10 baspoint))
    (setq i -1)
    (while (setq e (ssname sset (setq i (1+ i))))
    (cond
    ((/= 1 (cdr (assoc 66 (entget e))))
    (if (entget e) (progn
    (entmake (entget e '("*")))
    (entdel e)
    ((= 1 (cdr (assoc 66 (entget e))))
    (setq en e)
    (while (/= "SEQEND" (cdr (assoc 0 (entget en))))
    (setq en (entnext en))
    (entmake (entget en '("*")))
    (entdel e)
    (setq name (entmake '((0 . "ENDBLK"))))
    (if name (progn
    (entmake (append
    '((0 . "INSERT"))
    (if name (entlast) nil)
    ) ;end
    > I use several applications that create unnamed blocks (when they are
    listed,
    > they are named *U)
    > Can I do this in LISP? How about VBA?
    > If so, how?
    192.168.1.1
  • Brats
    Brats over 5 years ago in reply to StephenH
    I tried this code but look somehitng missing.
    (setq blocktype 0)
    (entmake (append
    '((0 . "BLOCK"))
    (setq i -1)
    (cond
    (entdel e)
    (setq en e)
    (entdel e)
    (if name (progn
    (entmake (append
    '((0 . "INSERT"))
    ) ;end
    10.0.0.0.1
