  2. Functional Verification
  3. #ifdef #else #endif inside module instantiation in Veri...
  • Replies 8
  • Subscribers 67
  • Views 27376
#ifdef #else #endif inside module instantiation in Verilog
aarthymani
aarthymani over 8 years ago
Hi all,
             I am trying to reverse engineer an open source verilog code for learning purpose. The code has some similar structure as below(please ignore my syntax errors)
                         module tb_trail();
                              test dut (
                                   .a(out)
                                   .b(in1)
                                #ifdef TRAIL
                                     .c(in3)
                                #else
                                      .c(in4)
                                #endif
             I have some basic knowledge in Verilog, and compiling it with INCISIVE. But when i try to compile the above module, I am getting error for missing either left or right parenthesis (*E,EXPLPA).
            Wondering, where is my mistake. Does INCISIVE(irun) supposed to understand those statements? is there a runtime option i need to specify to clear it? for your info, the definition for "TRAIL" is found with *.vh file  and I included it with -incdir option, and also added -vlog_ext +.vh to my run command
            Could someone help?
Thanks in Advance!
Aarthy
  • StephenH
    StephenH over 8 years ago
    The problem is you've got a typo, it should be "#ifdef TRIAL" but you put "TRAIL". Only kidding ;-)
    Your real problem is not the ifdef pragmas, it's the missing commas between the port connections.
    Try this:
                             module tb_trail();
                                  test dut (
                                       .a(out),  // added a comma
                                       .b(in1) , // added a comma
                                    #ifdef TRAIL
                                         .c(in3)   //no comma because it's the last one in the list
                                    #else
                                          .c(in4)
                                    #endif
  • aarthymani
    aarthymani over 8 years ago in reply to StephenH
    Hi Stephen,
           Thanks for typo correction. As I mentioned, "Please ignore my syntax errors". The original codes runs pages and pages, so i tried to mimic the concept into a smaller code version.  I do have commas placed in those areas, the main focus of the question is on the #ifdef #else #endif itself.
          Does doing the instantiation with #ifdef PARAMETER works?  so far, i have never used or seen it before.
    Thanks!
    Aarthy
  • StephenH
    StephenH over 8 years ago in reply to aarthymani
    ifdef pragmas work everywhere; they are processed before any other syntax parsing and are independent of the Verilog code.
    It's impossible to ignore syntax errors when you're asking about a parser problem, so either provide us with a runnable example of your issue, or at least clean up the other errors so that we only look at the one you think is real. Slight smile
    I'm 100% certain that your issue has nothing to do with the ifdef/else/endif, it's far more likely that you've simply broken your original code by putting the ifdef in a way that either the true or false branch introduces a syntax error by, for example, having a comma in one branch and not in the other. You'll get a much quicker solution if you can share the full code either here or by filing a support request at support.cadence.com (better, if the code is confidential).
  • TAM1
    TAM1 over 8 years ago
    It looks like the person who created your Verilog example was using the C preprocessor to handle his defines and macros. Your example shows #ifdef which will work for C. The Verilog preprocessor uses the "accent-grave" character or backwards-single-quote `. It is in the far upper-left of my keyboard. Try this:
    `ifdef TRIAL
      .c(in3),
    `else
      .c(in4),
    `endif
  • StephenH
    StephenH over 8 years ago in reply to TAM1
    Good catch Tom, I've been writing C code all day and totally missed the # versus back-tick typo! Slight smile
  • StephenH
    StephenH over 8 years ago in reply to StephenH
    As ever though, this highlights why it's better to submit a runnable testcase rather than a broken code fragment that has multiple errors in it!
  • aarthymani
    Hi Stephen,
              I totally understand. It is my mistake :( I will make sure I will post a bug free/no syntax error codes in future. The code is based on open source License, so I wasn't sure whether I can just like post anywhere.  I should have checked before posting my example.  :(
    Tom, Thanks for your response. I will change and try to simulate, will update here.
    Thanks!
    Aarthy
  • aarthymani
    aarthymani over 8 years ago in reply to TAM1
    Hi Tom,
       Changing the " # " to " ` " does solve that missing parenthesis error.
       Thank you!
