  2. Functional Verification
  3. NC-Verilog user manual
  • Subscribers 68
  • Views 39239
anmos
anmos over 8 years ago
I am not able to trace the user manual of NC-Verilog. I need it, because I am trying to solve this issue: https://community.cadence.com/cadence_technology_forums/f/functional-verification/39910/replace-includes-with-in-line-modules---nc-verilog
Can anyone point me to an online source of the manual?? Thank you in advance for your feedback.
Kind regards,
anm
  • StephenH
    StephenH over 8 years ago +1
    All Cadence's product manuals are available online at http://support.cadence.com/ . If you haven't already registered there, simply use your corporate email address to register. You might need your licence…
  • anmos
    anmos over 8 years ago in reply to StephenH +1
    Hi Stephen, I registered for the support, thank you for this information. Also the trick with the "decompile " in ncsim, worked like a charm. I used the following command: ncdc -output ./mydc.v my_lib…
  • StephenH
    All Cadence's product manuals are available online at http://support.cadence.com/. If you haven't already registered there, simply use your corporate email address to register. You might need your licence server host iD, as part of the validation process, if so check with your IT or CAD team. Depending on how old a version of the simulator you're using, you should have access to the tool "cdnshelp" which gives you all the documentation in your Linux environment. Most tool releases for the last 5+ years should have cdnshelp included.
    As regards the conversion of `includes to a single inline file, I don't think there is any fully automatic way. If you can compile the code once with the include files, you might try using the "ncdc" utility to decompile the code back into a single file. Run "ncdc -help" for more info.
  • anmos
    Hi Stephen,
    ncdc -output ./mydc.v my_lib.top:snap
    and it did the job by bringing in-line all the "included" modules.
    Always helpful with your answers, thank you!
    Kind regards,
    anm
  • StephenH
    StephenH over 8 years ago in reply to anmos
    Great! I'm glad it worked for you, thanks for the update.
