  2. Functional Verification
  3. Is it possible to create two vcd files during the same ...
  • Subscribers 67
  • Views 16603
Is it possible to create two vcd files during the same simulation
sara8
sara8 over 7 years ago
I have to create two vcd files. One which starts at zero time and ends when a specific signal changes, and one which start right after.
Is it possible to do it with xceliun by tcl commands?
  • StephenH
    StephenH over 7 years ago +1
    Yes, that can be achieved using the "database" and "probe" commands, combined with a breakpoint on the signal that you want to wait for. There are many possible ways to do it, here's an example. database…
  • StephenH
    database -open timezero -vcd
    probe -create -name timezeroprobe -database timezero [scope -tops] -all -depth all
    database -open secondpart -vcd
    probe -create -name secondpartprobe -database secondpart [scope -tops] -all -depth all
    probe -disable secondpartprobe
    stop -create -condition {[value %d top.count] = 100} -command {probe -disable timezeroprobe; probe -enable secondpartprobe} -continue -delbreak 1
    You should take care to check that the above commands and arguments are suitably adapted for your own setup, please refer to the Simulator Tcl Command Reference.
  • sara8
    sara8 over 7 years ago in reply to StephenH
    Can you explain which command in your code close the first vcd?
