  2. Functional Verification
  3. Force X in gate level simulation
  • Subscribers 67
  • Views 18948
POUCO
POUCO over 7 years ago
How to initialize flops not having reset pin in gate level simulation?
I expected -ncinitialize to do. but it doesn't.
What is the best (simple) and general way for cadence simulator ?
Thanks in advance.
  • StephenH
    StephenH over 7 years ago
    Hi. You'll need to give us some more detail. Did you pass -ncinitialize to the elaboration command or the simulation one? Did it report any errors, and if so, what errors?
    Also your subject line conflicts with the content - are you trying to set flops to X (per the subject line) or initialise them to a 0/1 value?
    Login to support.cadence.com and search on ncinitialize, and you'll find a wealth of documentation and app notes for this; did you try that?
  • POUCO
    POUCO over 7 years ago in reply to StephenH
    I want to force X to 0 or 1. -ncinitialize works for reg in UDP also ? I used irun command to do elaboration and simulation all at once. There was not error and warning about it.
  • StephenH
    StephenH over 7 years ago in reply to POUCO
    UDPs can be tricky as they can override the initial values. Take a look at this app note for some ways to deal with it: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nTEPEA2&pageName=ArticleContent, or this one: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000tFllEAE&pageName=ArticleContent which explains how to find unreset flops and deal with them programatically.
    You shouldn't need to explicitly initialise to X, that should generally be the default, right?
  • POUCO
    I'm sorry I don't know Host ID to read your link now. I'll check at my company later.
    THANKS!
