  2. Functional Verification
  3. Prevent SimVision Schematic Viewer from Re-Zooming/Centering...
  • Subscribers 67
  • Views 2463
Prevent SimVision Schematic Viewer from Re-Zooming/Centering after tracing a signal?
BairStrokes
BairStrokes over 5 years ago
SimVision preferences have this option for the schematic tracer. Lets say I have a module port and wish to trace that  step by step (using double clicks). For small modules this works fine, but once you hit a large entity, the whole view re-zooms and you loose track where you actually left off.
I tried turning above option on and off, but it is always unsatifying. With the option it always zooms in very close, without it you  sometimes get thrown back to the 10000ft-view when a large module is added to the viewport.
I just want the tool to retain my zooming level and position and just add the traced connection, which I can then follow.
I didn't think that this was such a 'out of this world request' but I cannot seem to find the setting that does this. (basically I'm asking: do nothing but add the next stage of the traced wire)
Any help is appreciated!
  • Doug Koslow
    Doug Koslow over 5 years ago
    There is an issue with this preference setting also noted in the forum here:
    community.cadence.com/.../1369009
    As I mentioned in that note, please raise a support ticket with your Cadence AE regarding it. (Unfortunately, I do not have a workaround for it.)
    Thanks.
    - Doug
