  2. Functional Verification
  3. make xcellium process command display only uvm processes...
  • Subscribers 67
  • Views 14403
make xcellium process command display only uvm processes?
avidanefody
avidanefody over 5 years ago
I'd like to debug my UVM processes only (one of them is stuck somewhere). When I use the TCL *process* command I get 1000's of RTL processes.
What is the best way to filter this list to get only SV/UVM processes?
Avidan
  • StephenH
    StephenH over 5 years ago +1
    Are you using Indago (or SimVision)? There may be easier ways to figure out what's stuck where, using the GUI rather than Tcl. For example, Indago has a "debug" tab which contains an "Active Threads…
  • StephenH
    For example, Indago has a "debug" tab which contains an "Active Threads" viewer, where you can see / filter the list of all running threads. Clicking a thread there will open the corresponding source at the line the thread is stopped at.
  • avidanefody
    avidanefody over 5 years ago in reply to StephenH
    @StephenH thanks! does simvision has the same thing?
  • Doug Koslow
    Doug Koslow over 5 years ago in reply to avidanefody
    No, thread debugging is a new feature of Indago.
    - Doug
  • StephenH
    StephenH over 5 years ago in reply to avidanefody
    As Doug says, SimVision doesn't have the thread debugger. I do believe you have access to Indago though, and given how you're a fan of Python, Indago's native Python API should be a good reason to consider upgrading away from SimVision :-)
