  2. Functional Verification
  3. "Direction" of EEnet connection points?
  • Subscribers 69
  • Views 2924
DanHerbison
DanHerbison over 4 years ago
I am using EEnet in SystemVerilog models to get some analog behavior of the connections (ports?, pins?) of my models.
My question is about declaration of the "direction" of the ports, i.e. is there a difference in declaring an EEnet connection point as input, output or inout?  If so, what is the difference?  I am using ADE Explorer as simulator in a Virtuoso environment.
  • drdanmc
    drdanmc over 4 years ago
    I think you can sometimes end up with bi-directional connect modules in places where you may not want them if you use `inout` for ports that really should have been input only or output only.  The bi-directional connect modules can then sometimes slow down simulations.  So I tend to use input and output as much as possible.  Not to mention, if you're in a Virtuoso environment, then schematic check&save checks for things like floating inputs or shorted outputs if you're using input/output vs everything inout.
