  2. Functional Verification
  3. how to force the variables inside a class? i'm facing this...
  • Subscribers 68
  • Views 6282
how to force the variables inside a class? i'm facing this error "FOAUTO"
chetan somana
chetan somana over 2 years ago
My intention is to force variables inside a class of type uvm_component. But as I cannot show that confidential code, i'm trying to replicate a similar code.
Here i'm able to force the variable j inside the module main but unable to do a force on the variable num which is inside class example.
i tried to change the scope, but the simulator always throws "*E,FOAUTO: Invalid way of setting automatic variable:"
what is a valid way to force the variables inside the class. I've read the document on the force, but it mentions about verilog/vhdl objects.
  • tpylant
    tpylant over 2 years ago in reply to chetan somana +1
    I had to make num a static variable to be able to force it. class example; static rand int num; endclass
  • tpylant
    Can you show how you're trying to force obj.num and monitoring the value of obj.num?
  • chetan somana
    chetan somana over 2 years ago in reply to tpylant
    I have shown how im forcing the module variable and class variable. Not sure if I had answered the later question.
    My original test has many nested blocked inside a case and endcase block; My intention is to save time by forcing desired value of the case so I can just resimulate using reset instead of complile and simulate.
  • tpylant
    class example;
    endclass
  • StephenH
    StephenH over 2 years ago in reply to tpylant
    xcelium> force ci.b = 1
    xmsim: *E,FOAUTO: Invalid way of setting automatic variable: m.ci.b.
    Extended help:
    % xmhelp xmsim FOAUTO
    xmhelp: 24.01-a071: (c) Copyright 1995-2024 Cadence Design Systems, Inc.
    xmsim/FOAUTO =
    A force, release or delayed deposit command cannot be used on
    an automatic variable.  Automatic variables are Verilog variables
    declared in a class, automatic task or function.
    (Default severity: 'E')
  • chetan somana
    Now I can force on the static variables used in the verification environment.
  • chetan somana
    chetan somana over 2 years ago in reply to StephenH
    Understood how to use xmhelp.  Before this I was using like this " xmhelp FOAUTO" which hasnt worked.
