  2. Functional Verification
  3. Can I force or probe a signal in vhdl module from verilog...
  • Subscribers 66
  • Views 20473
Can I force or probe a signal in vhdl module from verilog top testbench?
archive over 19 years ago
At 2/07/2007 10:01 AM a message was posted to a thread you were tracking. -- RE: Using the Forum by hubertx
I heard some simulator has its own way to do that easily, can you give me a example code to do that with ncsim?
Originally posted in cdnusers.org by foster
    Hi Hubert,
    from a VHDL module you can probe/force any VHDL or Verilog signal using ncmirror and ncforce, refer to the following documentation:
    http://sourcelink.cadence.com/docs/files/Release_Info/Docs/ncvhdl/ncvhdl5.83/applications.html#1044121
    There is no mechanic to access a VHDL object from a Verilog module today.
    As a workaround you may instantiate a VHDL Mirror component inside your Verilog module. Inside this VHDL component you can use the ncmirror and ncforce functions as described above and connect the probed/force signals through the ports to local Verilog signals.
    F.
    Actually you can access a VHDL object from a Verilog testbench using the $nc_force or $nc_mirror routines. They're relatively new to NC-Verilog. I just looked them up and I see that they're documented in Chapter 19 of the NC-Verilog Simulator Help manual.
    Originally posted in cdnusers.org by TAM
    Thank you very much, I'll try that.
    Originally posted in cdnusers.org by hubertx
    we are facing a similar isue. We need to check connectivity between a source signal which is instantiated in a VHDL module and a destination signal which is instantiated in a Verilog noe. It is not clear if and how to use $nc_force command, which requires a value ('0|1)) iwith Formal Verification tool. Does soembody have ever tried that?
    Originally posted in cdnusers.org by maurizios
    In response to forcing signals in Formal, this cannot be done. To check connectivity, you would write a property to ensure the two signals are always the same like:
    // psl verify_signals : assert always (siga == sigb);
    If the source of the signal is a port of a module you can blackbox the module driving the signal or just use [b]cutpoint[/b] to free the driven signal from being driven by the design. Now IFV will drive this signal as a free input signal and allow you to verify the connectivity to the destination. Does this explaination make sense to you?
    Originally posted in cdnusers.org by jb
    Related to the last couple of posts, there was a paper presented at CDNLive in SJ last year regarding connectivity checking.
    Session 1.8: Formal Analysis of Padring Mux-Logic Using IFV (Incisive Formal Verifier)
    It talks about using Formal Analysis and assertions as a much more efficient way to solve the connectivity problem.  You might find it useful. It can be found at:
    http://www.cdnusers.org/CDNLive/SiliconValley2006Proceedings/tabid/366/Default.aspx?topic=Functional%20verification
    Originally posted in cdnusers.org by ccc
