  2. Functional Verification
  3. for/generate
  • Subscribers 66
  • Views 3507
for/generate
archive over 19 years ago
I am currently studying psl and having some doubts. I have done a simple edge detector to starting using psl, this is the edge detector:
module edge_detector(sign_i, // Input of the Edge Detector
             rise_o, // Rising Edge Output of the Edge Detector
             fall_o, // Falling Edge Output of the Edge Detector
             clk, // clock
             rst_b, // Synchronous Reset
//--------------------- Parameters Declaration ---------------------------------
   parameter SIZE = 1;
//-------------------- Inputs Declaration --------------------------------------
   input [SIZE-1:0]sign_i;
   input clk;
   input rst_b;
//---------------------- Outputs Declaration -----------------------------------
   output [SIZE-1:0]rise_o;
   output [SIZE-1:0]fall_o;
//------------------- Types Declaration ----------------------------------------
   wire       clk;
   wire       rst_b;
   wire [SIZE-1:0]sign_i;
   wire [SIZE-1:0]rise_o;
   wire [SIZE-1:0]fall_o;
   reg  [SIZE-1:0]sign_i_syn;
   reg  [SIZE-1:0]out_ff2;
   wire [SIZE-1:0]out_xor;
   genvar i; // auxiliar variable to generate
 generate for(i=0;i
   begin
//------------------------ Sequential Part ------------------------------------
   always @(posedge clk)
     begin
       if (!rst_b)
     begin
            sign_i_syn[i]
     end //if(!rst)
       else
     begin
        sign_i_syn[i]
           //Transform the entering signal in synchronous
        out_ff2 [i]
        //Update the second ff output value
     end //else
     end //always @(posedge clk)
//-------------------------------- Combinational Part ------------------------
   assign out_xor[i] = (sign_i_syn[i] ^ out_ff2[i]);
// keeps the output from the xor in 1 for 1 period of clock in the rise or fall
   assign rise_o[i] = (sign_i_syn[i] & out_xor[i]);
// if the entering sinal has high level and the pulse in the xor output
   // represents a rising edge
   assign  fall_o[i] = ~(sign_i_syn[i] | ~out_xor[i]);
// if the entering sinal has low level and the pulse in the xor output
   // represents a falling edge
   end // for (generate)
 endgenerate
As can be seing above it is sizeble by parameter. So I have tried to also make sizeble psl.
In the psl introduction from cadence I have found this option:
for i in {0,1,2} generate
begin: check1
    {// psl check_init: assert (!value[i]) @rose(resetn);
end
endgenerate;
So I have tried this:
begin: check1
{//psl RISING: assert always ( rose(sign_i[0]) -> next PULSE(rise_o)
// abort !rst_b)
// report "Rising Edge Failed " severity warning;
//@fell(clk);
end
endgenerate;
And I had this bunch of errors:
ncvlog: *E,EXPLPA (EdgeDetector.v,122|4): expecting a left parenthesis ('(') [12.1.3(IEEE 2001)].
ncvlog: *E,EXPEND (EdgeDetector.v,124|4): Expecting the keyword 'end' [12.1.3(IEEE 2001)].
ncvlog: *E,NOTSTT (EdgeDetector.v,124|33): expecting a statement [9(IEEE)].
ncvlog: *E,EXPSMC (EdgeDetector.v,124|52): expecting a semicolon (';') [10.2.2][10.2(IEEE)].
ncvlog: *E,EXPSMC (EdgeDetector.v,124|63): expecting a semicolon (';') [9.7.3(IEEE)].
ncvlog: *E,EXPSMC (EdgeDetector.v,124|64): expecting a semicolon (';') [9.7.3(IEEE)].
ncvlog: *E,EXPSMC (EdgeDetector.v,124|71): expecting a semicolon (';') [9.7.3(IEEE)].
endgenerate;
My next try was to use the regular generate form in verilog:
generate for(i=0;i
begin: Rise
// abort !rst_b)
//@fell(clk);
end
endgenerate
It really worked, but the probes did not worked!! They are set like this:
probe -create -assertions -transaction -waveform -name RISING edge_detector_tb.edge_detector.Rise[0].RISING
The log result is:
ncsim> probe -create -assertions -transaction -waveform -name RISING edge_detector_tb.edge_detector.Rise[0].RISING
Created probe RISING
Even in the assertion browser, when I click in the assertion and put type transaction it do not appers in the SimVision. It shows no error, only doesn't apper.
Could somebody show me the best way of doing this and explain me why this ways did not work?
Originally posted in cdnusers.org by alexsieh
    Well, in my newbe condition in this forum I had problem posting the codes :)
    The first code is :
    clk, // clock
    parameter SIZE = 1;
    input clk;
    input rst_b;
    wire clk;
    wire rst_b;
    generate for(i=0;i begin
    begin
    if (!rst_b)
    begin
    sign_i_syn[i]<=1'b0; //If reset occured clear flip flops
    out_ff2<=1'b0;
    end //if(!rst)
    else
    begin
    sign_i_syn[i]<= sign_i[i];
    out_ff2 [i] <= sign_i_syn[i];
    end //else
    endgenerate
    The Second:
    begin: check1
    end
    endgenerate;
    The third:
    begin: check1
    // abort !rst_b)
    //@fell(clk);
    end
    endgenerate;
    The fourth:
    generate for(i=0;i begin: Rise
    // abort !rst_b)
    //@fell(clk);
    end
    endgenerate
    The sixth:
    Thanks and sorry about that,
    I tried doing this using IUS 6.11 and everything seemed to work fine for me. I did have to interpolate a little since the code that I cut-and-pasted from this thread needed some massaging to compile.
    Your original syntax problem appears to be because you put some PSL code into your HDL model without using the "// psl" comment prefix. So the Verilog parser was trying to parse the PSL as if it was Verilog. If the Cadence examples have code without the PSL prefix in them, then I think that they are wrong. Can you point me to the document you were referencing?
    Secondly, using a Verilog loop-generate seems to work fine. If anyone can tell me how to upload a 'tar.gz' file to this forum, I could post an example that takes everything thru the process and displays the assertion as a transaction in a waveform window at the end. Personally, I think it is a little too much code to post in-line.
    Originally posted in cdnusers.org by TAM
    HI,
    To attach a file do not use "Quick Reply" but click "Add Reply instead.
    You can use the "Message Attachments" field to attach files to upload.
    JB
    Originally posted in cdnusers.org by jb
    Ok then. :-)
    Here is a small example that, if you run it using IUS 6.11, should pop up a waveform window with your assertion displayed as a transaction.
    pslgen.tar.gz
