  2. Functional Verification
  3. Calculating Throughput & hence Band-width
  • Subscribers 66
  • Views 6152
archive over 19 years ago
Hi Guys,
Wanted to calculate the throughput in case of accessing memory.If consecutive write & reads are ther how we can prove that so and so throughput is achieved.need to consider the total time taken for access or how?
Thanks.
Originally posted in cdnusers.org by vlsi_dude
    Hello:
    You may consider use several cover statements to time the memory access latency using formal analysis. Take single read as an example: we can roughly guess the read latency using following cover properties in SVA and then run formal analysis:
    cover_rd_latency_2: cover property (@(posedge clk) read_en ##2 read_vld); (Fail)
    cover_rd_latency_3: cover property (@(posedge clk) read_en ##3 read_vld); (Pass)
    cover_rd_latency_4: cover property (@(posedge clk) read_en ##4 read_vld); (Fail)
    In the above example, we can find single memory read latency is 3 cycles.
    We can apply the same technique to time the memory latency/bandwidth for different combinations of consecutive read/write commands.
    Hope this helps,
    Darrow
    Originally posted in cdnusers.org by darrowchu
