  2. Functional Verification
  3. System verilog and System C
  • Replies 7
  • Subscribers 66
  • Views 22887
archive over 20 years ago
is there any resource showing how to write a verification environmentment mixing Sytem verilog and System C? A complex application example would be great
Cheers
Originally posted in cdnusers.org by marco.stanzani
    I'm working on finding/creating an example for you that I will post soon.
    Tim
    Originally posted in cdnusers.org by tpylant
    Before working on an example, can you clarify what types of SV constructs or objects you'd like to access. Are you refering to classes, structures, and/or enums or did you have something else in mind?
    Here's an excerpt from a paper that will be delivered by Leena Singh at DVCon next month:
    A. Interfacing to SystemC at Signal Level
    Port/signal connectivity is required between the verification environment and the DUT for driving or monitoring or both. A DUT TLM written in SystemC must be connected to a testbench written in SV or e or any other verification language.
    Following is a simple example of a SystemC signal declaration in the TLM.
    1. SC_MODULE(my_module){
    2. ...
    3. sc_inout my_sig;
    4. ...
    5. };
    6. NCSC_MODULE_EXPORT(my_module);
    Taking an example of SV with SC, a Verilog shell module must be defined for the purpose of instantiating the SC module (this shell can also be automatically generated by tools or scripts for example ncsc_run from Cadence generates it during compilation). This shell defines the ports whose name and type match the SystemC ports. The
    following Verilog shell must be created.
    1. // Module name must match exactly the name of
    2. // sc_module class in SC
    3. module my_module(...,inout [31:0] my_sig, …)
    4. (* integer foreign = “SystemC”; *);
    5. //port declarations for my_sig etc.
    6. endmodule
    The foreign attribute string value in line number 3 must be SystemC. The data types in both languages must match. Using this Verilog shell for SC, the SV testbench can communicate to any of the SC ports. For the data type communication, the values from the type in one language are mapped to an appropriate type in the other language.
    B. Interfacing to SystemC via Method Calls
    SystemC models define the methods the testbench must communicate with. Here is an example of a method in a SC model that is used for sending a packet:
    1. sc_module (my_module) {
    2. ...
    3. xbus_response send_packet(xbus_request & req);
    4. ...
    5. };
    The SV Direct Programming Interface (DPI) can be used for connecting an SV testbench to SC method ports. The DPI enables direct calling of SC functions in the SV testbench code. For example:
    1. import “DPI” function response send_packet(request req);
    2. // “xbus_response” and “xbus_request” are packed structs
    Once the SystemC method is imported into the SV testbench, it can be used in the same way as any other SV function or task.
    Some essential guidelines for composing a verification environment to connect to any DUT abstraction are:
    · Connectivity must be established with either the RTL or the SystemC model.
    · For reusability, the BFMs and monitors connected to the DUT interface should support all abstraction levels. The injection mechanism used in the transaction level BFM is simple. It does not have to implement the entire bus protocol. It need only transport the transaction to the model.
    · There should be an option to easily switch between various configurations supporting different abstractions.
    · Compatible data types should be used to communicate between language interfaces. For complex data types, a conversion utility is
    necessary for converting from one language to another. Verilog or VHDL ports of vector type of any direction or size can be mapped to SC data types of the same size.
    o Avoid the use of SC ports of type long or unsigned long, as they could lead to behavioral differences between 32-bit and 64-bit installations. You can use int or int64.
    o Connection of SV packed array or packed struct objects must have matching vector widths.
    o User-defined data types must be defined using the source code that is appropriate for each language.
    o If a type mismatch occurs between a port conected to a SystemC port, data might be truncated during simulation.
    · Each transaction level model can have a different API. It is better not to connect the VE directly to the model. Instead create a wrapper between the BFM/monitor and the model API. If the model API changes, data conversion can be done in the wrapper.
    · Special attention must be paid to the synchronization of events shared between the model and the VE monitors.
    As far as I can read from LRM, class is not allowed through DPI, but I can see that to be a very good value addition. Is there an enhancement to IEEE 1800 on this? BTW, will NC support class sharing across SV and SystemC?
    Regards
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
    archive over 19 years ago
    I am curios to know if there is an effective tool available which can convert System C code into verilog/vhdl code?
    Originally posted in cdnusers.org by sharib.khan@hp.com
    Hi Sharib,
    As far as I know, even if there is a tool to convert SYstemC into verilog, it would only convert the synthesisable subset of systemC into verilog (and this could have severe restriction on SystemC coding styles). Doing a web search, I could find:
    http://www.opencores.org/projects.cgi/web/sc2v
    I also know that there are some companies which synthesis SystemC. I do not know if they can produce verilog.
    Nitin
    Originally posted in cdnusers.org by nitin_sharma
    Hi tpylant,
    I have searched the forum throughly and found your post. I am very interested in the paper you mentioned. Could you share it on the forum?
    Best regards,
    Davy
    Originally posted in cdnusers.org by davyzhu
