  2. Functional Verification
  3. Constraints, randomize bits in a vector
  • Subscribers 66
  • Views 19344
archive over 20 years ago
I want to randomly set a weighted random number of bits in a vector.
The code below randomizes the number of bits that are set based on the weights provided, but I haven't figured out how to insert the weighted random number of bits randomly in a vector.
I have some code commented out that was an idea I had, which may be wrong, but functions in constraints doesn't seem to be supported.
I'm using IUS5.6-s2. Thanks.
To run: ncverilog sv_test.v +sv
module sv_test();
class constraints;
bit [31:0] bit_vector;
rand bit [31:0] bit_vector_rand;
rand bit [5:0] count;
constraint c0 {
count dist { [1:5]:/40,[6:25]:/20,[26:31]:/40 };
function int count_ones ( input bit [5:0] w );
for( count_ones = 0; w != 0; w = w >> 1 )
count_ones += w & 1'b1;
endfunction
// constraint c1 {
// count==count_ones(bit_vector_rand);
function void post_randomize();
bit_vector = {{32{1'b1}},{32{1'b0}}} >> (32-count);
$display("%d",count);
$display("x%h",bit_vector);
// $display("x%h",bit_vector_rand);
endfunction
endclass
constraints a = new;
integer num_iterations;
integer seed;
initial begin
num_iterations = 10;
if ($value$plusargs("SEED=%d",seed)) begin
$display("Using SEED=%d", seed);
end else begin
$display("Using default seed");
end
process::self.srandom(seed);
for (int i = 0; i
if ( a.randomize() == 0 ) begin
$display("%d error!",i);
end
end
end
endmodule
Originally posted in cdnusers.org by ross.weber@unisys.com
    I used a randc to generate a non-repeatable number to use as the location to put the '1'.
    module sv_test();
    class constraints;
    randc bit [4:0] place;
    constraint c0 {
    function void assign_bit ();
    // $display("Assigning 1 to bit %d", place);
    bit_vector[place] = 1;
    endfunction
    endclass
    initial begin
    set_seed();
    for (int i = 0; i < num_iterations; i++) begin
    a.bit_vector = '0;
    end
    place_randomize(a.count);
    end
    end
    function void place_randomize(input bit [5:0] bitcnt);
    for (int i = 0; i < bitcnt; i++) begin
    if (a.randomize(place)) begin
    a.assign_bit();
    end
    end
    $display("count = %d",bitcnt);
    $display("vect = %b",a.bit_vector);
    endfunction
    function void set_seed ();
    integer seed;
    end else begin
    end
    endfunction
    endmodule
    Originally posted in cdnusers.org by tpylant
    Great! Thanks!
    Did you notice that the larger numbers didn't always set the right number of bits? Take a look below at the count of 31. It only set 27 bits. Bug?
    ncsim> run
    Using default seed
    count = 26
    vect = 01101111111111011101110111101111
    count = 31
    vect = 11111111111011100111111100111111
    count = 2
    vect = 00000000000000000000000011000000
    count = 1
    vect = 00000000000000010000000000000000
    count = 29
    vect = 11111111011111110111111111111110
    count = 2
    vect = 00000001000000000000000000000001
    count = 27
    vect = 11001010111111111111111111011111
    count = 29
    vect = 01111111111101101111111110011111
    count = 2
    vect = 00000000000010000000000000100000
    count = 29
    vect = 01111111111111110101111111110111
    Good catch. The problem was caused because I never reset the place object, so it kept incrementing through the 32 choices. There might be a better way to reset a randc object, but I did it by deleting and recreating the class for each iteration. Here's the modification:
    constraints a;
    initial begin
    set_seed();
    a = new;
    a.bit_vector = '0;
    $display("randomize a error!");
    end
    a = null;
    end
    end
    test posting
    www.xtreme-eda.com
    Originally posted in cdnusers.org by coreygoss
