  2. Functional Verification
  3. SystemVerilog DPI in NCSim?
  • Replies 13
  • Subscribers 66
  • Views 31940
archive over 19 years ago
Hi all, Because it will take some time waiting download IUS583, I tried to use SystemVerilog DPI (mostly imported functions). I heard that Synopsys can simply include C file in file list with SystemVerilog file and run simulation. But Cadence NC seems need C code compile and link to a lib. I have read the NCsim document and find a switch "-sv_lib". But I cannot find a simple example. Is there any step by step tutorial about how to compile, link and run SystemVerilog DPI C file in NCsim? Best regards, Davy
Originally posted in cdnusers.org by davyzhu
    Hi vikask,
    Some suggestions listed below:
    1. Please restart another thread to describe your problem.
    2. If the command and environment file can be open to public, please paste it in the post.
    Davy
    Since this thread has been re-opened, I'd like to mention that Cadence has created a utility called 'irun' (i for Incisive) that is superceding ncsc_run, ncverilog, etc. This utility will allow you to pass in any combination of files that will get compiled correctly based on file name extension, i.e. .vhd, .v, .sv, .c, .cpp. You can also give it command line options either from the 3-step process or the +args from ncverilog.
    So, irun will answer the original question in this thread about being able to pass your DPI code and SV code with one command and have it take care of all the housekeeping.
    Tim
    Originally posted in cdnusers.org by tpylant
    I have to plan a verification environment where I can use some existing C++ ref Model code.I want to use System C libraries for that purpose. Only confusion I have is that, How can I drive and monitor HDl signals from System C? I saw some posting in cdnusers mentioning SC_MODULE signals being connected to Verilog signals, however, i don't know where to get more on this. A pointer for documentation will be helpful. Also, does this SystemC connectivity comes in NC verilog license? Is this free i.e. comes with NC verilog or need to buy a separate license for doing this. Also, earlier we had testbuilder which worked well with C++ in my earlier company but now I dont see testbuilder anymore. Please help me out in this. Thanks,
    vikas
    Originally posted in cdnusers.org by vikask
