  2. Functional Verification
  3. sys. verilog code - need explanation
  • Subscribers 66
  • Views 2193
archive over 19 years ago
HI, I am new to s.verilog - any help with the code below will be great!
what does the code below actually mean? anyone explain plz?
why is LOC_IDLE triggered?
LOC :
        begin
          varc_sel[3:0] = { LOC_DRAIN ,
                                  LOC_GETDEL ,
                                  LOC_BUFDEL ,
                                  LOC_IDLE } ;
          case (varc_sel[3:0])
            4'b1000 ,
            4'b0100 ,
            4'b0010 ,
            4'b0001 ,
            4'b0000 :
              begin
              end
            default :
              begin
                 $write("ERROR:");
                 $display(" Invalid arc in, fsm:SM, state:LOC") ;
                 $display(" Instance: %m");
                 $display(" Time: %t", $time);
Originally posted in cdnusers.org by indeb
    Somewhere I assume varc_sel is defined to be an enum like: typedef enum bit [1:0] {LOC_DRAIN, LOC_GETDEL, LOC_BUFDEL, LOC_IDLE} loc_t; loc_t [3:0] varc_sel; The way enums work is that you can refer to the labels by name, but underneath there are actual values for those labels. By default, it starts with 0 and counts up. You can change the default behavior by providing your own values in the definition. If you used the defaults, then LOC_IDLE would be equal to 3 which would never be selected in the case. However, you could use the following enum definition to make the assignment one-hot: typedef enum bit [1:0] {LOC_DRAIN=1, LOC_GETDEL=2, LOC_BUFDEL=4, LOC_IDLE=8} loc_t; Tim
    Originally posted in cdnusers.org by tpylant
    hi tim, thanks alot - but the invalid arc is asserted - is this coz enc_idle is 3 - and it goes into the default?
    how does case work? - seems like a basic qn - but i jus moved from process to design...
    thanks so much!
    Yes, you are correct. The way the case works is it looks at the value of varc_selA and then selects the branch that matches the value. In the example, if the value is 8, 4, 2, 1, or 0 it will branch to the 'begin...end'. If it doesn't match any branch, then the default branch will be executed.
    I'm reposting my previous text since the formatting got screwed up.
    typedef enum bit [2:0] {LOC_DRAIN, LOC_GETDEL, LOC_BUFDEL, LOC_IDLE} loc_t;
    loc_t varc_sel;
    typedef enum bit [2:0] {LOC_DRAIN=1, LOC_GETDEL=2, LOC_BUFDEL=4, LOC_IDLE=8} loc_t;
