  2. Functional Verification
  3. ncelab: *F,INTERR: INTERNAL ERROR , debug
  • Subscribers 66
  • Views 4497
archive over 19 years ago
Could anyone help to debug this issue is it a tool issue or code issue.....
I'm getting the following error for simulation....the code compiles fine..i have written a separate interface file along with clocking block in it....code for interface file is not shown here.....
TOOL: ncelab 05.82-p002
`timescale 1ns/1ns
module top;
bit Clk24 = 0;
bit ResetN = 0;
always #12 Clk24 = ~Clk24;
gfsktx_top_if tx_gfsk_if(Clk24);
GfskTxTop dut ( .Clk(Clk24),
                .ResetN(tx_gfsk_if.ResetN),
                .S2PIn(tx_gfsk_if.S2PIn),
                .ValidIn(tx_gfsk_if.ValidIn),
  .TxEnable(tx_gfsk_if.TxEnable),
                .Gfsk2DacI(tx_gfsk_if.Gfsk2DacI),
  .Gfsk2DacQ(tx_gfsk_if.Gfsk2DacQ),
                .ValidOut(tx_gfsk_if.ValidOut)
//classes
class gfsktx_bfm;
 //virtual gfsktx_top_if sigs;
 //function new
 //function new(virtual gfsktx_top_if sigs);
 // tx_gfsk_if = sigs;
 //endfunction: new
 //task reset sequence
 task resetsequence();
  //semaphore sem = new(1);
  //if(!sem.try_get(1)) $stop;
  $write("task reset sequence entered\n");
  tx_gfsk_if.ResetN
  tx_gfsk_if.S2PIn
  tx_gfsk_if.TxEnable
  tx_gfsk_if.ValidIn
  repeat (2) @top.Clk24;
  //sem.put(1);
 endtask: resetsequence
 //checking reset
 task resetcheck();
  //semaphore sem_1 = new(1);
  //if(!sem_1.try_get(1)) $stop;
  @Clk24;
  assert(tx_gfsk_if.Gfsk2DacQ == 'b0);
  assert(tx_gfsk_if.Gfsk2DacI == 'b0);
  assert(tx_gfsk_if.ValidOut == 1'b0);
  @Clk24;
  //sem_1.put(1);
 endtask: resetcheck
 task load_data(integer count);
  int cnt;
  cnt = count;
  //semaphore sem_2 = new(1);
  //if(!sem_2.try_get(1)) $stop;
  tx_gfsk_if.ResetN
  tx_gfsk_if.S2PIn
  tx_gfsk_if.TxEnable
  while(cnt != 0)
  begin
   tx_gfsk_if.ValidIn
   @Clk24;
   tx_gfsk_if.ValidIn
   repeat(23)@Clk24;
   cnt--;
  end
 endtask: load_data
endclass: gfsktx_bfm
gfsktx_bfm gfsktx;
//gfsktx_test gfsktx_test();
initial
 begin
  gfsktx.resetsequence();
  repeat(20) @Clk24;
  gfsktx.resetcheck();
  repeat(20) @Clk24;
  gfsktx.load_data(20);
  repeat(300) @Clk24;
  $finish;
 end
endmodule: top
Originally posted in cdnusers.org by chaitu2k
    I noticed that you are running with the IUS5.82-p002 release so first I suggest you try to get the latest release.
    I added an empty DUT and a simple interface definition to you test and it ran without an internal error.. Just two assertion errors.
    So... the problem could be in the interface definition or the DUT. I've attached my simple files. Try running with this on your testcase so we can determine if the problem is with the IUS5.82 release or the other code.
    interface gfsktx_top_if(input bit clk);
    logic ResetN, S2PIn, ValidIn, TxEnable, Gfsk2DacI, Gfsk2DacQ, ValidOut;
    endinterface : gfsktx_top_if
    module GfskTxTop (input bit Clk, ResetN, S2PIn, ValidIn, TxEnable, Gfsk2DacI, Gfsk2DacQ, output bit ValidOut);
    endmodule
    Originally posted in cdnusers.org by kameade
    Hello kameade,
    Thanks for your help. Its the tool problem. This code runs fine in the next version of the tool(IUS5.83-s001).
    Cheers
    Excellent!
    Have a great weekend.
    Kathleen
    Can I suggest that, once you have the error figured out, you submit a SourceLink request for this? They are very good about changing "INTERNAL ERROR" messages into helpful messages if you can show them the problem. This means that the next poor bloke who runs into this will get a meaningful error message.
    Dave F.
    Originally posted in cdnusers.org by dfechser
