  2. Functional Verification
  3. Replication Patterns
  • Subscribers 66
  • Views 18120
archive over 19 years ago
Look what I got!
    preamble =   '{PREAMBLE_SIZE{40'hDDDDDDDDDD}};
ncvlog: *E,APTYPE (/lsi/ftc/yampa_design/users/dfechser/experimental/lib/lsi_uvc_lib/lsi_nrz/sv/lsi_nrz_package.sv,81|32): Assignment Pattern - replication patterns unsupported at this time (PREAMBLE_SIZE) [SystemVerilog].
...anyone know when ncverilog will support this (PREAMBLE_SIZE is a variable)?
Dave F.
Originally posted in cdnusers.org by dfechser
    I'm assuming that PREAMBLE_SIZE is a parameter. In that case, you could try to add another set of brackets like
    parameter PREAMBLE_SIZE=16;
    preamble = '{{PREAMBLE_SIZE{40'hDDDDDDDDDD}};
    David Walker
    Originally posted in cdnusers.org by dwalker@sirenza.com
    PREAMBLE_SIZE is an input to the "new" function and is used to set the size of the dynamic array.
    When I added the extra brackets I get an error that says "Illegal operand for constant expression" which sounds closer than I was before.
    I need to figure out how to tell SV that the function input is a constant, I guess.
    Hm, I tried "const ref" and "const ref int" and both give me the same error message:
    Does anyone have any ideas?
    What I have is a transaction with resizeable preamble, data, and flush fields so I want to set them in the new() function and use dynamic arrays to hold the parts.
    replication patterns are not currently supported, something like the following works in 5.8. not the most elegant, but the underlying implementation would need to do the same....
    module temp;
    parameter PREAMBLE_SIZE = 16;
    bit preamble[];
    initial
    begin
    preamble=new[PREAMBLE_SIZE];
    for (int i=0; i preamble[i]=40'hDDDDDDDDDD;
    end
    endmodule
    Originally posted in cdnusers.org by Jim McGrath
    If it's a parameter, why not do
    module temp;
    bit [PREAMBLE_SIZE*40-1:0] preamble;
    initial begin
    preamble='{{PREAMBLE_SIZE{40'hDDDDDDDDDD}}};
    end
    endmodule
    It compiled for me in 5.83. I assume the OP wanted to pass it to a task as a parameter like
    module test;
    // the dynamic array must be defined here because it is invalid in a task
    bit preamble[];
    task xxx(input int PREAMBLE_SIZE);
    preamble = new[PREAMBLE_SIZE*40];
    endtask
    initial begin
    xxx(13);
    xxx(10);
    end
    endmodule
    When I did this, I got the same error messages as the OP. I tried your for loop trick in the above and it worked OK.
    David Walker
    yeah, my bad. The issue is with replication initialization which is not currently supported. ~jm
