  2. Functional Verification
  3. Wand Wires to be driven by Program Block and Module blo...
  • Replies 10
  • Subscribers 66
  • Views 20912
Wand Wires to be driven by Program Block and Module block
archive over 19 years ago
Hi All,
I have a design that have some bidirectional signals, driven one side by Verilog Module, next side by SV testbench.
But signals should have a functionality of wand (wire-and) type only
Both are interacting through SV Interfaces only.
Three combinations I tried:
  1. from SV testbenchn,  if I decleare  logic a , b , it give errors inout port must be a net type
  2. when I declare them as  wand a,b, and it give error while driving them through TB, it give error usage of 'intf_inst.b' inconsistent with 'net' object.
  3. when I declare with input and output types, it give error blocking and non-blocking assignments to heirarchical references in a program block are illegal
What's the solution?
Regards
Mayank
Sample code is as such
interface intf( input logic clock);
wand a,b;
modport port (inout a,b);
endinterface
program main (intf intf_inst);
 int count =0;
initial begin
    while (1) begin
    #10;
        intf_inst.b = 1'b1;
        count = count +1;
        if (count >1000) $finish;
    end
end
endprogram
module top;
    reg data_value, clock;
    intf intf_inst (clock);
    main m(intf_inst.port);
     assign  intf_inst.a = data_value;
    initial begin
          clock =0;
        forever begin
              #10 clock = ~clock;
        end
    end
endmodule
Originally posted in cdnusers.org by mayank
    Or putting in simple terms, How to assign values to wire signal types of interface from a class object ??
    i.e. how to make it possible to change
    class_intf_inst.a =0; by calling the function         p.change_interface();
    As it is giving the error This or another usage of 'class_intf_inst.a' inconsistent with 'net' object
    sample code is:
        wand a,b;
    endinterface
         int count =0;
         class packet;
              virtual intf class_intf_inst;
              function new (virtual intf intf_inst);
                    class_intf_inst =intf_inst;
              endfunction
              task change_interface;
              endtask
           endclass
          packet p =new (intf_inst);
    initial begin
        while (1) begin
            #15;
            $display ( "program a = %b, b = %b ",intf_inst.a, intf_inst.b);
            count = count +1;
        end
      end
      assign intf_inst.b = count[0];
      assign intf_inst.a = 1'b1;
    endprogram
    task indp_task;
    endtask
    module top;
        main m(intf_inst);
        initial begin
              clock =0;
                forever begin
                      #10 clock = ~clock;
                      $display ("    top a = %b, b = %b ",intf_inst.a, intf_inst.b);
                end
        end
    endmodule
    Even though this is SystemVerilog, you still have to deal with some of the restrictions enforced by the underlying Verilog language itself. In that language, you cannot make behavioral assignments directly to a "net" type. A net type like wand can have multiple drivers. You can only make behavioral assignments to a single driver of the net. Then Verilog will resolve the multiple drivers into their final value.
    wand a,b;
    logic b_driver;
    assign b = b_driver;
    endinterface
    int count =0;
    initial begin
    while (1) begin
    #10;
    intf_inst.b_driver = 1'b1;
    If you truely wanted the port to be bidirectional, you might want to put a control on the behavioral driver you are creating:
    wand a,b;
    logic b_driver,b_ctrl;
    assign b = b_ctrl ? b_driver : 'bz;
    endinterface
    Originally posted in cdnusers.org by TAM
    Thanks Tam for your information. But in this case we are increasing the no. of wires in the interface (as we are adding logic type signals to be driven by SV TB),  which is not according to the standard or specification.
    Any turn-arounds for it ?
    Regards
    Mayank
    If you can't instantiate the external driver in the interface (which is a resonable restriction), then you'll have to instantiate it elsewhere, probably in the block that describes the dut's environment. This works:
    wand a,b;
    endinterface
    int count =0;
    initial begin
    while (1) begin
    #10;
    intf_inst.b = 1'b1;
    count = count +1;
    end
    end
    endprogram
    module top;
    initial begin
    clock =0;
    forever begin
    #10 clock = ~clock;
    end
    end
    endmodule
    % more testit.sv
    wand a,b;
    endinterface
    program main (intf intf_inst, output logic b_driver);
    int count =0;
    initial begin
    while (1) begin
    #10;
    b_driver = 1'b1;
    count = count +1;
    end
    end
    endprogram
    module top;
    // External drivers for bi-directional pins
    logic b_driver;
    assign intf_inst.b = b_driver;
    main m(intf_inst.port,b_driver);
    initial begin
    clock =0;
    forever begin
    #10 clock = ~clock;
    end
    end
    endmodule
    Nice Suggestion
    Thanks Regards
    Mayank
    Oops, sorry about the double post of the original source code there.
    Fine. Do we have to keep passing  this output logic b_driver, all the way to class object instances and thier functions. For small designs its OK, but for bigger designs and testbenches, it will  become too cumbersome.  Where you are assigning by multiple object functions etc.
    Any turn around for this ??
    Regards
    Regards
    Oops sorry !! for triple post, including this post.
    I'm sorry that you find this burdensome. But it is the way that the Verilog language works. If you have multiple drivers on a net, you will have to describe each of them and assign their values separately. You are going to have to "keep passing" something around to the different blocks of code that can change the driver's value. How does it differ between passing the resolved net or its external driver?
