  2. Functional Verification
  3. Reg : problem with reg declaration in IUS58
  • Subscribers 66
  • Views 16283
archive over 19 years ago
Hi all, I have declared a data member as reg. when i use it in an assign statement, I am supposed to get an error.Now 1. If i use the +sv switch i am not getting an error. 2. its showing an error if i do not use the +sv switch,which is as expected. I am using cadence IUS58, please clarify on this. thanks Manmohan
Originally posted in cdnusers.org by mssajwan
    Hi Manmohan,
    If the data member is used on transaction layer, please declear it as bit (0/1) or logic (0/1/x/z).
    Best regards,
    Davy
    Originally posted in cdnusers.org by davyzhu
    Hi Davy,
    I have used the declaration inside a module
    module test();
    reg a,b;
    assign a = b ? 1 : 0 ;
    endmodule
    in this code with +sv command line option its not giving me an error.
    In SystemVerilog, such code is now legal. Here's a snippet from the LRM:
    SystemVerilog extends the functionality of variables by allowing them to be either written by procedural statements or
    driven by a single continuous assignment, similar to a wire.
    A wire can have multiple continuous assignments, like drivers on a bus. A reg can only have a single continuous assignment.
    Originally posted in cdnusers.org by TAM
    Hi TAM,
    thanks a lot for the reply. my doubt is now clear even though i have not checked the LRM but your comments
    are sufficient.
    thanks & regards
    Manmohan Singh
