  2. Functional Verification
  3. NCSIM SV constraint Fatal error
  • Subscribers 66
  • Views 16606
archive over 19 years ago
Hi Cadence,
I have written a case about constraint.
Class A (Sequence have some command) composite Class B(command).
And Class A and Class B have some constraints.
ncsim: rnc_bool.h:110: rnc_bdd_node& rnc_bool_node::get_bdd_node(): Assertion `_bdd_node_valid' failed.
ncsim: *F,INTERR: INTERNAL ERROR
Observed simulation time : 25 NS + 0
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
  TOOL: ncsim   06.10-p001
  HOSTNAME: shpc024
  OPERATING SYSTEM: Linux 2.4.21-32.ELsmp #1 SMP Fri Apr 15 21:17:59 EDT 2005 i686
  MESSAGE: Unexpected signal #6, program terminated (null)
Best regards,
Davy
Originally posted in cdnusers.org by davyzhu
    Another fatal error,
    I guess all the fatal errors are caused by constraint solver.
    Error:
    terminate called after throwing an instance of 'std::bad_alloc'
    what(): St9bad_alloc
    HOSTNAME: shpc024
    Best regards,
    Davy
    Hi
     Even we face the same .Can somebody give guidelines in making constraint .sometimes randomize function takes 10 minutes to find solutions
    Prabhu,G
    Originally posted in cdnusers.org by prabhu_G
    Hi Prabhu,
    I guess you may use some layers of implication -> to accelerate the constraint solver.
    Anyone have some constraint trick to share?
    Best regards,
    Davy
