  2. Functional Verification
  3. array initialization [1a] (system-verilog)
  • Subscribers 67
  • Views 25768
archive over 19 years ago
Using the IUS 5.83 version, I'm trying to
compile these simple SV code lines:
parameter    ports_num                  = 4;      // ports number
integer px_num[ports_num-1:0];    // pixel num x port
initial
begin
  px_num[ports_num-1:0] = { 4'h8, 4'h8, 4'h6, 4'h6 };
end
and I got the following errors
Compiling SHM component...
file: /IPREUSE/DATABASE/INTERNAL/DIG/INPROGRESS/gborgo/simd_A0_a/config/../generic/rtl/svlog/shm.v
ncvlog: *E,NOPSOM (/IPREUSE/DATABASE/INTERNAL/DIG/INPROGRESS/gborgo/simd_A0_a/config/../generic/rtl/svlog/shm.v,117|7): part-select or indexed part-select cannot be applied to memory [4.2.2(IEEE)].
        module simd.shm:v
                errors: 1, warnings: 0
Is it a problem of the IUS 5.83 version ?
BR
Giampiero Borgonovo
Originally posted in cdnusers.org by borgonov69
    archive over 19 years ago +1
    The error is caused because you used specified a range on the assignment after already declaring the type. You have two choices for the fix. integer px_num[ports_num-1:0] = '{default:4'h6}; …
    My guess is that ncvlog sees your file as V2K and not as SV. Did you turn on the -sv flag to ncvlog? Your file extension is .v, hence is my doubt on that. Other than that, you should use an aportophe with array assigns as in:
    Instead of:
    Use:
    px_num[ports_num-1:0] = '{ 4'h8, 4'h8, 4'h6, 4'h6 };
    The following code should compile and run just fine. try it out!
    Ajeetha, CVC
    www.noveldv.com
    module m1; parameter ports_num = 4; // ports number integer px_num[ports_num-1:0]; // pixel num x port initial begin : b1 px_num[ports_num-1:0] = '{ 4'h8, 4'h8, 4'h6, 4'h6 }; end endmodule : m1
    Originally posted in cdnusers.org by ajeetha
    or
    initial begin
    px_num = '{default:4'h6};
    end
    For more examples, refer to IEEE1800, sec 8.13.
    Tim
    Originally posted in cdnusers.org by tpylant
    Why is that a problem? It becomes an array slice.
    Shalom
    Originally posted in cdnusers.org by shalom
    This solution solves the syntax issue.
    The issue is originated by the Esperan System verilog for designers manual (version 2.7) that I'm using
    as reference.
    Thanks.
    BR
    Giampiero
