  2. Functional Verification
  3. When is the next version of nc expected?
  • Subscribers 66
  • Views 15413
archive over 18 years ago
Hi, I'm using ncvlog 6.2 and would like to know if a new version is expected soon. Also, if someone can please point me to a document that specifies which SV features are unsupported and in which future version they are supposed to be supported, I would be extremely thankful. Thanks a lot, Avidan
Originally posted in cdnusers.org by avidan_e
    I would expect the next major release of ncvlog to appear some time in the spring, if we keep to our current major release schedule. If you are asking about an update version with bug-fixes, they usually appear every couple of weeks or so.
    We can't make any predictions of when a particular feature will appear in the future since there can be all sorts of liabilities if a problem causes a milestone to be missed. What our R&D has asked us to request when we see a question like this is "What specific capabilities are you interested in?"
    If you would post your answer here, I'll pass it on to Cadence R&D. I think it is obvious that they'd prefer to work on features that real-life customers are asking for, rather than trying to anticipate their needs in a vacuum.
    Originally posted in cdnusers.org by TAM
    Hi TAM,
    My own private curse are template classes. I hope you (Cadence) are aware of the fact that the irun solution for creating specializations is not even close to being a sufficient one, and is also quite bugged. I spent the last few days tearing apart and destroying a piece of elegant SV code, whose only fault was that it had template classes, so that it can load (I didn't run it yet) with nc.
    If I'm already there: I'm using irun 6.20-p001. Is there a fast way of knowing if there are new patches and bug fixes?
    Avidan
    You can sign up on Soucelink for email notifications of new versions. I'll occasionally go to downloads.cadence.com and look at the software versions available under the IUS62 link. Right now it says that update 002 is available. Go to the "software update" link on the home page and then "setup notification".
    I'll have to admit that I've never used it myself, but there is a template class preprocessor available with 'irun', called svpp I think. Is that the "irun solution" you've mentioned? Perhaps other readers of this forum can help you with that.
