  2. Functional Verification
  3. Help Needed for multiple transactions
  • Subscribers 66
  • Views 15901
archive over 18 years ago
Hello Friends,
    I'm coding a UVC(Universal Verification Component) in System Verilog Class Based methodology. For the protocol, which I've coded, I could successfully get one complete transaction. But I couldn't get second transaction or any successive transactions.
   I'm getting struck at "get_next_item"(for second trasaction)....I tried to debug but couldn't proceed further.
So, could someone help me in removing this problem so that I could get multiple transactions.
Thanks in advance,
Jalli
Originally posted in cdnusers.org by jaally
    I think you are not creating custom sequence and setting default_sequence of the sequencer. Please look at the xbus uVC example on how to create custom sequence and use it by calling set_config_string() call.
    e.g.
          set_config_string("*tx_agent.driver", "default_sequence", "cdn_pack_tlm_sequence");
    By default, the sequencer will run a simple sequence which only creates one transaction.
    Originally posted in cdnusers.org by pjigar
    Thanks PJigar!
    It did help me!
    Jalli
    Hi Jally,
    I guess you Want to get Conigure Count  to Get Multiple transactions.
    "urm_driver" has a int Variable 'count' with which u can have Multiple Transactions just as in eRM,
    Use  set_config_int("*.driver","count",5);  in the Main_sve Class. you will get 5 Transactions for this Config.This will Solve your Problem.
    Ramesh Pal
    Originally posted in cdnusers.org by ramesh_pal_yadav
    Hi Pal,
    This is even cool! Anyway, thanks for that additional point.
    Jalli
