  2. Functional Verification
  3. non deterministic ff in verilog :
  • Subscribers 66
  • Views 15000
archive over 18 years ago
Hello, one of my FF's is implemented as follows : always @(posedge clk) data 1 / data 0 / prev_data 1 -> 0 i get different results on 2 run (after 1 cycle) one time 'data' remains 0, and on another run it rise from 0 to 1. i assume it caused since in the time of the clk rise, prev_data is falling, and therefore, 'data' doesn't succeed in sampling on time. is it possible that verilog is not deterministic in this case ? thanks,
Originally posted in cdnusers.org by zcabeli11
    A proper testcase with wave diagrams can help explain your problem better. But quickly using the #1 is considered old style. You don't need it if you are using NBA
    always @(posedge clk) data <= prev_data
    Also, don't forget the reset for your FF.
    HTH
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
    hello ajeetha,
    would it be ok of ii send you the wave results on email ?
    thanks,
