  2. Functional Verification
  3. overriding the module parameters
  • Subscribers 66
  • Views 24560
archive over 18 years ago
Hi everyone,
I have created a test bench which has some parameters and it instantiate a module which also has some parameters on its on. i pass the test bench's parameters to the parameters of the instance of the module and it works fine however when i try to override the test bench's parameter during the simulationg, it gives the following error:
Error: (vsim-3852) Invalid override of parameter
i do the following to simulate
vsim -GWIDTH=16 -GADDR_BITSD=9 tb
(WIDTH and ADDR_BITS are parameters of test bench which are passed to parameters of an instance of a module within the test case)
this is how i defined my test bench parameter
module tb #(parameter WIDTH=16,parameter ADDR_BITS=9);
this is how i instantiated the module within the testbench
generator#(WIDTH,ADDR_BITS) g1 (.*);
could someone tell me what could i do during the simulation to override parameters of the test bench ?
Originally posted in cdnusers.org by ROOZ
    I can't help you out much since vsim is the command for executing Mentor's simulator. However, with Cadence Incisive simulator it would be:
    % irun -defparam GWIDTH=16 -defparam GADDR_BITSD=9 tb
    Tim
    Originally posted in cdnusers.org by tpylant
    thanks alot for quick response to the thing is that i am sure that -G works fine with vsim because i tested it with another module but the actual mistrey to me is that when i try to override the top level file, it won't allow me to override the parameters.
    this is the actual error vsim 3852
    vsim Message # 3852:
    # Once parameters for a module have been frozen, further redefinition
    # is not permitted. This error results from attempting to modify
    # parameters in an optimized design (compiled with -fast) by using
    # a separately compiled defparam or by specifying -G to vsim.
    i dont understand why i get this error for my test bench but not the module that instantiate within the test bench. what i mean is that the module instantiated within the test bench has its own parameters and outside the test bench i was able to test -G by overriding the parameters of that specific module. I have no clue why -G doesn't override in test bench too?
    I think you did not understand my comment that this is a Cadence board and therefore you might not get much help in solving a problem for a non-Cadence product such as 'vsim'.
    Tim
    I understood what you said Tim, but i am limited to use Questa
    but as i mentioned before, vsim worked for me but in this special case is not working.
    i need a way to override the parameter during simulation using QuestaSim 6.3
    hey Tim,
    I finally got it to work, the only problem was the optimization which was occuring during the simulation
    the solution is -novopt. The -novopt switch instructs the compilation process to create the necessary information for
    simulations without optimization. this solved my problem. i hope it would help anybody else who is facing this problem.
