  2. Functional Verification
  3. configuration of eVC
  • Subscribers 66
  • Views 15403
archive over 19 years ago
    I have OCP eVC. In my environment 3 instances of this eVC to be present. But these 3 instances will have different configuration parameters. The following the one such configuration.
The default OCP signals in the eVC are defined as below:
   sig_Maddr : inout simple_port of uint is instance;
   sig_Mdata : inout simple_port of uint(bits:128) is instance;
In my environment i need to constrain the above signals to be ,
   sig_Maddr : inout simple_port of uint (bits :8 ) is instance;
   sig_Mdata : inout simple_port of uint(bits: 32) is instance;
How can we constrain the signals as above.
-Arjun.
Originally posted in cdnusers.org by arjuny
    You do not need to change the e port declarations in the OCP eVC in order to connect it to signals that has smaller bit width. Instead you should just simply 'bind' the signals from your RTL to e port without thinking about bit width mismatch. Specman will automatically do type conversion for you.
    e.g.
    keep bind (sig_Maddr, external);
    keep sig_Maddr.hdl_path() == "rtl_signal_sig_Maddr";
    keep sig_Maddr.agent() == "Verilog";
    Look at the example files in /examples directory to see more examples on signal binding.
    Originally posted in cdnusers.org by pjigar
    thanks for the reply.
