  2. Functional Verification
  3. instance declaration :
  • Subscribers 66
  • Views 15335
archive over 18 years ago
what is the difference between the following 2 instance declarations: 1. x is instance 2. a : x is instance my common sense tells me it's something about the naming of the struct. in the first case the name is determined determined defaultly to be 'x', whereas in the second case it's 'a'. is it correct ? thanks,
Originally posted in cdnusers.org by zcabeli11
    Yes your understanding is correct.
    Find the complet explaination below :
    Syntax for taking unit instance -
    field-name[: unit-type] is instance
    Parameters
    field-name : The name of the unit instance being defined.
    unit-type : The name of a unit type.
    If the field name is the same as an existing type, you can omit the ": unit-type" part of the field definition. Otherwise, the type specification is required.
    Gaurav Patel.
    ASIC Engineer.
    eInfochips.
    www.einfochips.com
    Originally posted in cdnusers.org by er_gauravpatel
    Posted By zcabeli11 on 1/21/2008 11:51 PM
    I would recommend to avoid the short form and use different names for unit types and their instances. It just makes life easier :-)
    Originally posted in cdnusers.org by thinkverification
