  2. Functional Verification
  3. binding of simple inout ports to hdl wire (specman 6.2)
  • Subscribers 66
  • Views 15961
archive over 18 years ago
   I am trying to bind simple inout ports to hdl wires. Specman tool is giving the following error. (specman tool version 6.2)
           *** Error: Bound sets cannot have an external inout port with other
        external ports.
         sys.simple_evc.smp.sig_DBus: NCVLOG inout simple_port of uint (bits: 32)
                 Also externally connected to agent 'NCVLOG',
                 using hdl_path() 'DBus'
    The following is the sample code used for binding the simple port
     sig_DBus : simple_port of uint(bits:32) is instance;
       keep soft sig_DBus.hdl_path() == "DBus";
       keep sig_DBus.declared_range() == "[31:0]";
       keep sig_DBus.verilog_wire() == TRUE;
       keep bind(sig_DBus, external);
    What could be the reason for this error?  and how to get around from this problem?
Thanks & Regards,
Arjun.
Originally posted in cdnusers.org by arjuny
    Hi Arjun.
    Is there another port in your system that has the same hdl_path?
    Yaron
    Originally posted in cdnusers.org by thinkverification
    Hi Yaron,
    this is the only port that has this hdl path. Also it is the case for all the ports declared in the port map file.
    -Arjun
