  2. Functional Verification
  3. how can i detect X value
  • Subscribers 66
  • Views 15558
archive over 18 years ago
Hello, i'm using ticks to read data from verilog wire. however, when the wire contains invalid value (x) it gives me defauls zero. how can detect this invalid value ? thanks,
Originally posted in cdnusers.org by zcabeli11
    Use ports instead - they're faster, safer and have built-in methods for doing X checks etc.
    Originally posted in cdnusers.org by stephenh
    i used simple port to bind a name with it's verilog corresponding element. and then called the method has_unknown( )
    thanks,
    You can also use the MVL API with simple ports to both sample and drive X/Z values safely.
    Originally posted in cdnusers.org by jhzhang
    The following example gives the x detection on simple port
    a : simple_port of bit is instance;
    if(a.get_mvl() == MVL_X) {
    out("unknown value was detected on verilog wire");
    Originally posted in cdnusers.org by arjuny
