  2. Functional Verification
  3. delta delay issues...
  • Subscribers 66
  • Views 16897
archive over 18 years ago
    In my design i have two signals clock and data. the data(both are one bit signals). Data is changing exactly at the rise of the clock.
    In specman environment i am using the "@sim" to sample the clock.
   What value will be sampled by the specman at every rise of clock? (does it sample previous value or the updated value of data)
Originally posted in cdnusers.org by arjuny
    Hi Arjun,
    If data is assigned using a blocking assignment (= in verilog), then you will see the new value in Specman. If it is assigned using a non-blocking assignment (<= in Verilog) then you see the old value (like other flops on the HDL side).
    Please look atthe Specman docs, book: "Incisive® Enterprise Specman Elite® Testbench
    Integrator's Guide Version 6.2" "9.5 Synchronizing with the Simulator (Callbacks)"
    Hope this helps,
    Dean
    Originally posted in cdnusers.org by ddmello
