  2. Logic Design
  3. naming style for generate statement in RTL
  • Subscribers 63
  • Views 19838
diablo
diablo over 16 years ago
 I have a generate statement in my verilog RTL.
 generate
        for(g=0; g<num_reg; g=g+1) begin
            wb_reg #(._address(reg_addr[g*_width+:_width]), ._default(reg_default[g*_width+:_width]),
                    ._bit_mask(reg_bit_mask[g*_width+:_width]), ._autoclr(reg_autoclr[g*_width+:_width])) wb_regs (
                .CLK_I(CLK_I),
                .RST_N_I(RST_N_I),
                .TEST_EN_I(TEST_EN_I),
                .ADR_I(SADR_I),
                .DAT_I(SDAT_I),
                .DAT_O(dat_o[g]),
                .ACK_O(ack_o[g]),
                .CYC_I(SCYC_I),
                .STB_I(SSTB_I),
                .WE_I(SWE_I),
                .REG_SEL_O(reg_sel_o[g]),
                .REG_DATA_O(reg_data_o[g]),
                .REG_DATA_I(ro_data[g*_width+:_width]),
                .REG_UPDATE_I(reg_update_i[g]));
        end
    endgenerate
After synthesizing with RC 8.1, the netlist generated for this block has following naming style.
 wb_reg__address8h03__default8h08__bit_mask8h8f__autoclr8hff\genblk1[0].wb_regs
Same naming sytle is in SDF file generated for this design using write_sdf  -design foo -version "OVI 3.0" -delimiter "/" > ${_OUTPUTS_PATH}/${DESIGN}_netlist.sdf .
The problem is "." before wb_regs is causing syntax issue when running simulation using SDF file. The error is
 ncsdfc: *E,SDFIRE: "../../../synthesis/foo/outputs/foo_netlist.sdf", line 50115: Syntax error ".".
ncelab: *W,SDFCNC: Cannot compile SDF file, ../../../synthesis/foo/outputs/foo_netlist.sdf - skipping annotation.
I have tried
 set_attribute hdl_array_naming_style "%s_%d"
set_attribute hdl_array_generator "%s_%d"
set_attribute hdl_reg_naming_style "%s_reg%s"
in synthesis scripts but none of these fix the problems.
Is there a certain attribute related to module generate naming style that may fix the problem. Pls suggest.
Thanks for your time.
  • grasshopper
    grasshopper over 16 years ago
     Hi Diablo,
     in RC91 you can use the following
       attribute name: hdl_generate_index_style
              category: elab (controls elaboration)
           object type: root
           access type: read-write
             data type: string
         default value: %s[%d]
                  help: Format of 'for generate' block labels.
        attribute name: hdl_generate_separator
           object type: root
             data type: string
         default value: .
                  help: String used to separate generate block labels.
    I am not sure if RC81 also had these
    gh-
  • diablo
    Thanks gh. I appreciate your help. It worked  after using those two attributes.
  • mclarke
    mclarke over 16 years ago
     Hi diablo,
       Three other attributesare used to control the naming style for generate statements in RC
    # Specifies whether 'if' generate labels should be used to prefix instances, default true, allowed [ true | false ]
    set_attr hdl_use_if_generate_prefix           false    /
    # Specifies whether 'for' generate labels should be used to create instance names, default true, allowed [ true | false ]
    set_attr hdl_use_for_generate_prefix          false    /
    # String used to separate generate block labels, default "."
    set_attr hdl_generate_separator                  ""    /
  • diablo
     Thanks mclarke, this is even more helpful.
  • angelster
    angelster over 16 years ago
     Badly needed this2 attributes, glad to find it here..thanks
