  2. Logic Design
  3. memory LEC
  • Subscribers 63
  • Views 15475
memory LEC
WorldMaker
WorldMaker over 16 years ago
Hi all,
We always model the RAM as a flop in RTL simulation, can verplex LEC check the equivalence between the RAM RTL(shown below) and the RTL using verplex built-in RAM primitives?
/////////////Example/////////////////////////////////////////////////////
module mem2p (wclk,wadr,wdin,rclk,radr,rdout);
parameter adrbits=7;
parameter databits=8;
parameter adrmax = (1<<adrbits)-1;
input wclk;
input [adrbits-1:0] wadr;
input[databits-1:0] wdin;
input rclk;
input [adrbits-1:0] radr;
output[databits-1:0] rdout;
reg[databits-1:0] rdout;
reg[databits-1:0] mem[0:adrmax];
always @(negedge wclk) mem[wadr] = wdin;
always @(posedge rclk) rdout=mem[radr];
endmodule
thanks,
worldmaker
  • croy
    croy over 16 years ago
    Hi Worldmaker
    Please let us know if Sean's reply in your other post didn't cover this one as well.
    Chrystian
  • WorldMaker
    Hi Chrystian,
    I asked the same question in my other post, and I am still working on it. Actually it's not progressing smoothly due to my lacking experience in Conformal and especially in memory equivalence check.
    Briefly, I want to check the equivalence between the golden RTL and the transistor-level schematic of a custom designed memory. The golden RTL consists of some interface logic, test logic and also a memory core which was shown above.
    My trial solution is to divide it into 3 steps:
    1st:   build a new RTL, acutally a ram wrapper which is comprised of a conformal memory primitive, interface and test loigc. let's name it as bridge RTL tempororarily;
    2nd: equivalence check between the transistor-level schematic and the bridge RTL;
    3rd:  equivalence check between the bridge RTL and the golden RTL.
    I am still working on the 2nd and 3rd steps, and seems that I have not found out the right commands. Frankly, I wonder if Conformal can handle the 3rd step.
    thanks,
    Justin
