  2. Logic Design
  3. RTL compiler - eleborate issue.
  • Subscribers 62
  • Views 3626
sandeepsuhas
sandeepsuhas over 16 years ago
Hi All, I am trying to synthesize the verilog code using RTL compiler. When I use the following commands, I am facing problems in elaborating the design. It is not able to take the operating_condition , any help would be appreciated. set_attribute lib_search_path { /home/ssriram/project/rc } set_attribute script_search_path { /home/ssriram/project } set_attribute hdl_search_path { /home/ssriram/project } set_attribute path /home/ssriram/project set_attribute library tt_1p2v_25c.lib set file_list mult.v read_hdl $file_list elaborate -libpath /home/ssriram/project/verilog -libext .v mult.v I am facing the following error Error : Invalid operating_conditions name. [LBR-32] [elaborate] : Library has no operating conditions named 'tt_1p2v_25c'. : Use ls to see the valid operating_conditions in the libraries. Error : Error when processing libraries loaded into domain. Cannot continue unless all domains' libraries are OK. [LBR-115] [elaborate] : Error when processing domain: /libraries/library_domains/_default_ Failed on elaborate -libpath /home/ssriram/project/verilog -libext .v mult.v Regards Sandeep.
  • mclarke
    mclarke over 16 years ago
    Hi Sandeepsuhas,
      I can see a couple of issues here, first you need to do is find an operating condition by using;
     rc:/> find / -operating_condition *
    Next set one of these operating conditions using
     rc:/>set_attr operating condition my_condition /
    If I understand the script you are using is below, I would return after I've  loaded the lib to do the above steps. Once the lib is loaded cleanly I would change the "elaborate -libpath /home/ssriram/project/verilog -libext .v mult." to simple "elaborate". If errors are still occuring then the issues are within library or rtl and can't help unless we can see inside those.
     Cheers,
    return
    read_hdl $file_list
