  2. Logic Design
  3. verilog . D-latch with memory.
  • Subscribers 64
  • Views 18006
dvdeepak
dvdeepak over 16 years ago
Hi
can any one help me for the module and testbench of D-latch with memory.in this file attatched the figure has rd/wrd and clk are inputs and data is an inout. if rd/wrb is low then flip-flop is in write mode ;data are an input line;data on data line are written into latch when clk is positive. when rd/wrb is high , flip-flop is in read mode, data stored in latch are made available on data line..I tried alot but couldn't get it done.Please help.
Thanx.
  • tpylant
    tpylant over 16 years ago
    latch.v
    module latch (clk, rd, wr, d);
      input clk;
      input rd, wr;
      inout d;
      reg d_out;
      assign d = (rd && wr) ? d_out : 1'bz;
      always @(posedge clk) begin
        if (!rd && !wr)
          d_out = d;
      end
    endmodule
    test.v
    module test;
      reg clk = 0;
      reg rd, wr;
      reg d_in;
      wire d;
      latch i1 (clk, rd, wr, d);
      assign d = (!rd && !wr) ? d_in : 1'bz;
      always #5 clk = ~clk;
      initial begin
        @(negedge clk) rd = 0; wr = 0; d_in = 0;
        @(negedge clk) rd = 1; wr = 1; d_in = 0;
        @(negedge clk) rd = 0; wr = 0; d_in = 1;
        @(negedge clk) rd = 1; wr = 1; d_in = 1;
      end
      initial $monitor($time,,rd,,wr,,d);
    endmodule
    Tim
  • dvdeepak
     thanx for ur reply sir but could you plz tell me whts wrong with the 2 methods tht i tried and are not working.
    1st method
    module Dlatchwithmemnew2(q, data, rw,clk);   ///////// its not working , data and q are giving X as ouput
        output q;
        inout data;
        input rw,clk;
         wire en,qb;
         reg d;
         reg data_out;
         wire data_in=data;   /// i tried to put the data input into data_in
    Dlatch g1(q,qb,d,en); //// its a D latch with output q and qb
    assign data=(rw==1)?data_out:data_in;  /// to use the inout data
    assign en=(rw==0)?clk:1'b1; //// if rw=1 then clk will always be 1 so tht when q wil b given as input to D-latch again and will b written into it
      always @( clk, rw , data, q, data_in) begin
        if (rw==1)
         begin
         data_out=q;   /// output of d-latch is given into data_out
          d=q;                 /// q will be given as input to d-latch again
      end
      else
      begin
      data_out=q;
      d=data_in;            /// data_in will be given as input to d-latch
      end
      end
    endmodule
    2nd method tht i tried is .. data is not giving proper output even by using some temp_data as reg and then substituting its value into inout data
    module main(data, rw,ck);
        inout data;
        input rw,ck;  ///////////if we run the synthesis of main then there is error in tri0 and tri1
    wire wren,q,qb;//////////////but its test runs absolutely fine only by making the "data" as reg in test
    tri0 en;//////////////////// not as a wire
    tri1 d;/////////////////////whereas it should be wire coz of being an INOUT
    not(wren,rw);
    bufif1(d,data,wren);
    bufif0(en,ck,rw);
    bufif1 (data,q,rw);
    endmodule
    Deepak.
