  2. Logic Design
  3. Verilog simulation using verilog XL
  • Subscribers 64
  • Views 17902
OLyonnais
OLyonnais over 16 years ago
i want to simulate a sample MUX21 realised on my schematic. I think, before going on the verilog XL , i need to put a load capacitor (classical cap) at the output to be able to see my output signal Z.
Then, arrived on the verilog XL interface, when i lauch the simulation, i have this following error:
*************************on the icfb terminal; *****************************************
\o ---------- Begin Netlist Configuration Info ----------
\o                 (incremental data only)
\o
\o CELL NAME                   VIEW NAME            NOTE
\o ---------                   ---------            ----
\o
\o cap                         symbol               *Stopping View*
\o nsvtlp                      verilog              *Stopping View*
\o psvtlp                      verilog              *Stopping View*
\o MUX21                    schematic
******************************on the verilog XL terminal *************************************
 Message!  deleted TMS file 'verilog.tms' due to error in
          input file
                                                           [Verilog]
Error!    Module or primitive (cap) not defined            [Verilog-MOPND]
          "ihnl/cds0/netlist", 19: cap C0(.MINUS(
          cds_globals.gnd_), .PLUS(Z));
1 error
End of Tool:    VERILOG-XL    08.20.001-p   Jun  9, 2010  15:03:34
is the problem comes from to the view name of the capacity?
thank you
  • PranR
    PranR over 13 years ago
    Hi ,
              I am getting the error while simulating the Verilog  in cadence which is integrated with an inverter block made from nmos_hvt and pmos_hvt of PDK library. verilog is a symbol generated in cadence from the verilog file.
    Error!    Module or primitive (verilog) not defined            [Verilog-MOPND]
              "ihnl/cds0/netlist", 35:verilog  I12(net17,
             net15 , net21 , net19, net012, O1, O2, O3);
    Error!    Module or primitive (inverter) not defined            [Verilog-MOPND]
              "ihnl/cds0/netlist", 36:inverter  I13(.out(
             output_) , .in(net012)) ;
     Help !
  • tstark
    tstark over 13 years ago
    Hi, PranR.
    The modules "verilog" and "inverter" are not defined in your run for some reason. You need to read in the definition for the simulator to resolve the modules. It seems like you are using an integrated environment. Unfortunately I can only comment about the Verilog error.
    The code will look like:
    module verilog (in0,in1,out0,out1,clk,rstn);
    If it is not defined then you will get an error.
    Also, please start a new thread for a new topic rather than replying to an old thread.
    -ts
