  2. Logic Design
  3. Problems with IUS08.20.001 and Suse 11.2 64 bits
  • Subscribers 63
  • Views 14727
yanaek
yanaek over 16 years ago
 I am new to ncsim, ncverilog an simvision. I have just installed the IUS08.20.001 packet on my PC with linux - Suse 11.2 64 bits. No errors or problems reported during the SW installation.
I tried to run a simulation scrip that calls ncverilog, but  the script throws a - command does not exist.
Then, I try to find the tool with the ./cd_tools script and the answer was - unable to find cadence software.
The same happens with ncsim, but simvision works.
I do not know what is wrong.
 I will appreciate any help. Thank you!
Yana
  • mkapil
    mkapil over 16 years ago
    Hi Yana,
    For the IUS8.2 release SUSE11 is not a supported platform.
    You need to use a SUSE9 or SUSE10 machine.
    In general to check if a machine is supported for that release,
    you can use the script checkSysConf.
    This script will tell you if the machine will work with the current release.
    -Kapil
