  2. Logic Design
  3. defined clocks not propagate
  • Subscribers 63
  • Views 16297
tompy
tompy over 16 years ago
I have a design with clocks defined at root.I can use [get_attrbute  propagated_clocks] to get clock propagate at g152/Z,
however, I cannot get propagated clock at g151/Z
  XOR2D0HVT g151(.A1 (n_2), .A2 (clk2), .Z (clk2_inv));
  XOR2D0HVT g152(.A1 (n_2), .A2 (clk1), .Z (clk1_inv));
 I can also get propagated clock at g151/A2 and g152/A2
this is pretty weird since g151 and g152 are same logic, but I can't get propagated clock at g151 output!
can someone tell me why g151 block the clock propagation? thanks!
  • grasshopper
    grasshopper over 16 years ago
     Hi Tompy,
     hard to tell based on the information provided. Some issue that could possibly do this:
     + edit_neltist command on output of g151
    + constraint applied to output resulting on path segmentation
    BTW, are you hand-instantiating g151 and g152. What does incoming RTL look like ? What do incoming constraints look like ?
    thanks,
    gh-
  • tompy
     Hi gh:
    g151 and g152 are synthesized result, not hand-instantiating. its RTL is:
      assign clk1_inv = (!scan_mode) ? !clk1 : clk1;
      assign clk2_inv = (!scan_mode) ? !clk2 : clk2;
    and synthesized result is
      INVD0HVT g40(.I (scan_mode), .ZN (n_2));
     this is a huge design(10M+ gate counts), and the logic above is located at aaa/bbb/ccc/ddd/
    case1: If I extract ddd and directly create clock at clk1 and clk2, I can get propagated clocks at both g151 and g152
    case2: if I read in aaa and create clock at aaa input port clk1 and clk2, the issue I mentioned will occur.
    in case2 I try directly create clock at g151/A2 and g152/A2, for some reason, I still can only get propagated clock at g152/Z.
    I only read in netlist and create clock at clk1 and clk2, there is no other constraints, I did not set_case_analysis at scanmode port.
     thanks for the reply
    /tompy
