  2. Logic Design
  3. RTL Compiler: Manually Add Logic Gates
  • Subscribers 63
  • Views 14631
moogyd
moogyd over 15 years ago
I am trying to update some old (bgx_shell) scripts to RTL compiler (10).
This script basically performs some very basic logic isolation, but including AND gates.
e.g. Within i_subdes1 there is a net RC_TESTPORT
i_subdes1/RC_TESTPORT to connected to
- i_subdes1/i_subdes2/RC_TESTPORT
- i_subdes1/i_subdes3/RC_TESTPORT
I want to add an AND gate such that
i_subdes1/RC_TESTPORT connected to i_subdes/i_newgate/A1
i_subdes1/ISOLATE connected to i_subdes/i_newgate/A2
i_subdes1/i_newgate/X connected to  i_subdes1/i_subdes2/RC_TESTPORT
i_subdes1/i_newgate/X connected to  i_subdes1/i_subdes3/RC_TESTPORT
With bgx_shell, I used create_instance, delete_netconn, add_netconn and create_net. There are obvious alternatives for the first 3, but I am not sure about create_net.
I tried a simple experiment, and it connected RC_TESTPORT to i_newgate/A1 OK, but didn't manage to connect the AND gate output - it seemed to try and connect RC_TESTPORT to both the input and output of the AND gate.
I am not sure I understand where to use NETs and PORTs.
Does anyone have a script (or link) to a script that does something similar?
Steven
  • moogyd
    Just an update.
    I now have a solution - my previous problem was that I was confustion re pins/ports, and also not correctly making changes at the correct level of hierachy.
    I would still be interested in comparing my solution with other scripts that may be available.
    Steven
  • grasshopper
    grasshopper over 15 years ago
    Hi Steven,
    as you indicated, I think there are many ways to skin the cat. I believe it really depends what your exact needs are:
    + using edit_netlist commands is perfectly adequate
    + for isolation in the context of power you could rely on CPF infrastructure which will do the insertion for you based on power constraints
    + for isolation in the context of DFT you could rely on the insert_dft command if it meets your needs. I believe your goal is one of
       shadow logic support so check out the following command:
     c:/>  insert_dft shadow_logic -h
      insert_dft shadow_logic: inserts test logic to enable testing of shadow logic around a module
    Usage: insert_dft shadow_logic [-around <instance>+] [-mode <string>] [-auto] [-minimum_shadow_logic_pins <integer>]
               [-exclude_shadow_logic <instance>+] [-balance] [-preview] [-dont_map] [-test_control <test_signal>] [-test_clock_pin <pin|port>]
               [-rise] [-fall] [-group <pin>+]+ [-exclude <pin>+] [-only <pin>+]
        [-around <instance>+]:
            instances around which DFT shadow logic must be inserted
        [-mode <string>]:
            mode of operation {no_share|share|bypass}
        [-auto]:
            automatic shadow logic insertion
        [-minimum_shadow_logic_pins <integer>]:
            inserts shadow logic on blackboxes with pins exceeding this value (default: 10)
        [-exclude_shadow_logic <instance>+]:
            exclude shadow logic around these instances
        [-balance]:
            group unmatched inputs/outputs to have a balanced number of groups
        [-preview]:
            show what would be done only, but do not modify the design
        [-dont_map]:
            do not techmap the inserted logic even though design is mapped
        [-test_control <test_signal>]:
            test signal used to control the DFT logic
        [-test_clock_pin <pin|port>]:
            use this clock pin to trigger control/observation flops
        [-rise]:
            use rising edge of test clock
        [-fall]:
            use falling edge of test clock
        [-group <pin>+]:
            what pins to observe together and/or control to the same value
        [-exclude <pin>+]:
            do not control/observe these pins
        [-only <pin>+]:
            only control/observe these pins
    The nice thing about most insert_dft commands is they have a -preview option so you do not have to mangle your design and rerun to get it right. There are other insert_dft commands that may do what you want.
    + Finally there is insert_io_buffers for buffer-level isolation. This commands requires you to run 'include load_etc.tcl' to become accessible
    Please post back and report your findings.
     regards,
    gh-
