  2. Logic Design
  3. DONT USE cells & uncertainties
  • Subscribers 63
  • Views 1964
sureshm
sureshm over 15 years ago
 Hi All,
 This may a pretty  easy questions for most of the community in here. Can you please let me know the methodology of arriving @ the
DONT use list from the given technology library @ various levels of the implementation flow ..( synth, CTS,PnR, ECOs) ?
Also, I am not clear on the Uncertainty numbers being used for a design ?  What are all the things to keep in mind for te calculation of Uncertainties? Is it some blanket % use for the uncertainity or any connection with the Foundary details, and some analysis on the OCV numbers , Jiitter and so on.. ?
Thanks in advance
suresh
  • mclarke
    mclarke over 15 years ago
    Hi Suresh,
      There are a number of consideration used to determine which cells to avoid from a given library for a wide variety of reasons; electro-migration, delay, congestion, drive strength... unfortunately there is no simple answer to such a question and would require detailed understanding of the design intent and application.
      For the uncertainty yes it is use for a number of reasons including, cycle to cycle jitter, clock skew before clocktree insertion and margin for downstream effects like xtalk & detour routing. OCV while a real effect uses a different mechanism set_timing_derate command which is more appropriate for the condition.
    Cheers,  Mike
  • mclarke
     Hi Suresh,
    Cheers,  Mik
