  2. Logic Design
  3. RTL Compiler : Giving 1'b0 in synthesized netlist
  • Subscribers 63
  • Views 4829
deeps4
deeps4 over 15 years ago
Hi all,
 I have application  where I have to use a set-reset D flip flop and I need to connect the D input to set port of the flop.
I have written the RTL code for the same as a single bit flop and instatiated the flop as a 256 bit wide register as shown below
set_reset_dff  u_shell_output_cap_dff[255:0]
  .d          (q_int[255:0]),
  .set        (q_int[255:0]),
  .reset      (RST),
  .clk        (clk),
  .q          (Q[255:0])
However after  synthesis in the netlist I see following code with 1'b0 on the D input and where ever the flop is instantiated there also I see 1'b0 on D input. Basically RTL compiler is not connecting the set and D input of the flop. Any ideas what could be the reason? Is there a way to force it to short set and D input. I have also used "generate" to instatiate flop iso the code snippet above but see same result...
module set_reset_dff(d, set, reset, clk, q);
  input d, set, reset, clk;
  output q;
  wire d, set, reset, clk;
  wire q;
  wire n_0, n_1;
  df3qx2pdv q_reg(.CD (n_1), .SD (n_0), .CP (clk), .D (1'b0), .Q (q));
  ivpdv g19(.A (reset), .Z (n_1));
  ivpdv g20(.A (set), .Z (n_0));
endmodule
-DN
  • deeps4
    Preserving the set_reset_dff module  to dont touch worked for the above issue.
    -DN
  • grasshopper
    grasshopper over 15 years ago
    Hi DN,
    in all likelyhood, the implementation you described is functionally equivalent and likely more efficient. That being said, if your design has a strict requirement of keeping the topology you instantiated, the correct approach is to do exactly what you did and
    set_attr preserve true <seq instances list of interest>
    hope this helps,
    gh-
  • deeps4
     Hi gh,
     Apart from the above I had a general question. Using generate is better or the way it is instantiated above is better. I presume generate may take slightly more time to compile, both the methods synthesize to same logic. So was wondering if one is better over other...
    -DN
  • grasshopper
    Hi DN,
     I believe either one should work. In theory the impact should not be significantly any different. I would say the main reason to use generate statements or not would be if the naming convention of the generate statement has any impact in your flow.
     gh-
  • deeps4
    Thanks gh.
    -DN
