  2. Logic Design
  3. Timing report for a hierarchical block
  • Subscribers 63
  • Views 16203
Ivan de Trble
Ivan de Trble over 15 years ago
Hi everyone!
 Can anyone tell me how can I get a timing report for a net that goes through hierarchy?
In other words: the net starts at the current level then goes into a flip flop inside an instantiated custom block. I need to know the timing from the current level down to that flip flop.
 Thanks for your help.
  • grasshopper
    grasshopper over 15 years ago
    Hi Ivan,
    You can certainly apply
    set_attr break_timing_path true <hierarchical pin>
    external_delay -input <value> -clock <clock> <hierarchical pin>
    report timing -from <hierarchical pin>
     More importantly I have to ask you why you would want to do this? Individual segments of nets in synthesis will not necessarily correlate to your actual placement, especially if you are not using RC-P or a physically aware synthesis solution.
    regards,
    gh-
  • Ivan de Trble
    Grasshopper my friend, you are indeed correct: not one net, but 500+ of them.
    I apologize for my gross oversite when typing my cry for help.
    Knowing now what I need, what would you (or anyone out there reading this  message) recommend I do?
     Thank you for your help,
    Ivan
  • grasshopper
    Hi Ivan,
     you can easily script the solution described but ultimately I am not sure I understand the purpose of the exercise. If it is strictly for informational purposes, you might as well report in P&R where the numbers would be more accurate. Frankly, I would question the value of measuring parts of a net topology since lots of assumption have to be made about how to split certain parasitic effect when splitting a net. In such cases 1 + 1 != 2    :)
    hope this helps,
    gh-
