  2. Logic Design
  3. RC: clock gating
  • Subscribers 63
  • Views 18707
RC: clock gating
Yemelya
Yemelya over 15 years ago
What is the right way to insert clock gating in RC script?
I found the following flag:
               set_attribute lp_insert_clock_gating true
Is it enough or there is something else needed?
How should I translate the following instructions from DC for RC:
 set_clock_gating_style -sequential_cell latch \
 -control_point after \
 -control_signal scan_enable \
 -minimum_bitwidth 8 \
 -observation_logic_depth 6
 compile_ultra -gate_clock
Thank you very much!!!
Boris
  • grasshopper
    grasshopper over 15 years ago
     Hi Boris,
     set_attribute lp_insert_clock_gating true  /  (notice the '/' for the objec; do not forget those or you can infer the wrong thing)
     is the minimal.There are a fair number of option associated with clock gating that you enable in addition to that. A typical flow usually has
    define_dft shift_enable -name <SCAN ENABLE OBJECT NAME> -active high<SCAN ENABLE PORT>
    set_attr lp_insert_clock_gating true /
    set_attr lp_clock_gating_min_flops 3 [find /designs -design <DESIGN NAME>]
    set_attr lp_clock_gating_test_signal <SCAN ENABLE OBJECT NAME> <DESIGN NAME>
    As per your migration question
     would translate to
    define_dft shift_enable -name scan_enable -active high<SCAN ENABLE PORT>
    set_attr lp_insert_clock_gating true /  (default is false)
    set_attr lp_clock_gating_min_flops 8 [find /designs -design <DESIGN NAME>]
    set_attr lp_clock_gating_style latch [find /designs -design <DESIGN NAME>]     (default is latch)
    set_attr lp_clock_gating_control_point postcontrol [find /designs -design <DESIGN NAME>]     (default is precontrol)
    set_attr lp_clock_gating_test_signal scan_enable <DESIGN NAME>  (default is to tie CG test signal de-asserted)
     There is n equivalent for  -observation_logic_depth but you can do
     set_attr lp_clock_gating_add_obs_port true <DESIGN NAME>    (default is false)
    hope this helps,
    Diego-
  • Yemelya
    Diego thank you very much for so fast and detailed answer!!!
