  2. Logic Design
  3. Mismatch between RTL and synthesis result (CDFG-511)
  • Subscribers 61
  • Views 16724
archive over 21 years ago
I experience a mismatch between behavior of RTL and the Ambit Synthesis Result; whereby Ambit displays the following WARNING:
--> WARNING: Possibly an 'X' or 'Z' value propagated to a control statement
that may cause simulation mismatches between the original and
synthesized designs (File ../RTL/com.v, Line 3957) .
What is CDFG-511?
Details:
The design is an FSM which has outputs dependent from the next_state, i.e. mealy outputs. In the synthesis result the next_state after the power on reset evaluates to 'x' although the next_state is in this case only dependent from the current state which is well defined by the reset. Ambit involves additional signals in the calculation of the next_state, which are not defined at this time. Ambit Version is v5.7-s133.
Originally posted in cdnusers.org by weidi1
    Hello weidi1,
    We suggest you use the latest 5.14 version. The 5.7 version is about 2 yrs old. You might have some undriven signals propagated to the control logic. Check the settings of the variable hdl_undriven_net/port/pin_value and set it to the expected value in your design.
    CDFG (Control Data Flow Graph) indicates this warning occurs during the build_generic process where BG builds the generic data base from your RTL.
    Originally posted in cdnusers.org by synthman
    Hello synthman,
    Thanks for the hints.
    I tried 5.14 but the warning is the same as is the erroneos behavior of the synthesized circuit. The strange thing is, it works if I force Ambit to synthesize the output logic dependent on the next_state (and the current state) into a separate module; no warning, correct behavior.
    What do You exactly mean by ""undriven signals propagated to the control logic""?
    Hi weidi1,
    I meant there might be some undriven signal propagated to the control statement like 'case', 'if'. Do you see any undriven net reported from 'check_netlist'?
    Seems like this is something specific to your design that triggers the warning. I don't think we can resolve it here in this forum. If you can send that piece of RTL to Cadence Support, we can investigate further.
    archive over 20 years ago
    weidi1,
    Might be a stupid question, but is the problem occuring where you have a "case" statement in the code for defining which state is "next_state"?
    If so, does this case statement have an "others" clause covering all possibilities not explicitly in the rest of the statement?
    Might be worth checking.
    CD
    Originally posted in cdnusers.org by crispy_duck
