  2. Logic Design
  3. How to force RTL compiler to use a particular net name
  • Subscribers 63
  • Views 21499
deeps4
deeps4 over 14 years ago
I have a RTL which after synthesis looks as in  the snippet  mentioned below..
wire [2:0] seed_inp;
 wire [2:0] seed_outp;
output[2:0] seed_outp;
  wire scan_5_q, scan_9_q, scan_10_n_0, scan_10_q, scan_11_n_0,
       scan_11_q, scan_12_n_0, scan_12_q;
  wire scan_fix0_6_n_0, scan_fix0_6_n_1, scan_fix0_6_q,
       scan_fix0_8_n_6, scan_fix0_8_n_8, scan_fix0_8_n_14,
       scan_fix1_2_n_0, scan_fix1_2_q;
  df1qpdw scan_10_q_reg(.CP (clk), .D (scan_10_n_0), .Q (scan_10_q));
  mx21x2pdw scan_10_g22(.D0 (seed_inp[2]), .D1 (scan_10_q), .S0
       (scan), .Z (scan_10_n_0));
I wanted RTL compiler to take the above sinppet as
df1qpd scan_8_q_reg(.CP (clk), .D (seed_outp[2]), .Q (scan_8_q));
mx21x2pd scan_8_g20(.D0 (seed_inp[2]), .D1 (scan_8_q), .S0
       (scan), .Z (seed_outp[2]));
Functionality wise both are same but I am getting unnconnected  in the netlist because of this issue..
Is as written in the RTL and scan_9* scan_10* etc are as written out by RTL compiler after synthesis.
Is there a way I can force the RTL compiler not to use its own wire names but to retain the wire names as written in RTL ?
-DN
  • grasshopper
    grasshopper over 14 years ago
     Hi DN,
     I believe you are looking for this
       attribute name: write_vlog_preserve_net_name
              category: write (controls write output)
           object type: root
           access type: read-write
             data type: boolean
         default value: false
                  help: Determines whether to preserve net names present in user input or not.
    Note that dangling wires resulting in incorrectly implemented functionality would be a bug in the tool. Did you run LEC ? I suspect if the wire became unconnected it probably could be optimized out but obviously I have no knowledge of RTL or functionality
    gh-
  • deeps4
     Hi gh,
    I could not find that command in the manual. But some how that also did not help. May be I will try different version of RTL compiler and check.
    DN
  • deeps4
     Hi gh,
    The signal was getting optimized out. I have one generic question to you. How does these unconnected or optimised nets gets handled
     during PNR. I mean if the gate levels has few ports as "unconnected" how does this gets sorted out during further stages, will it be tied off?
    -DN
  • Rameen
    Rameen over 5 years ago
    did you find the solution?I am facing same issue
