  2. Logic Design
  3. RTL Compiler: Remove Empty Modules
  • Subscribers 62
  • Views 17412
moogyd
moogyd over 14 years ago
Hi.
During optimization, a lot of empty modules seem to be created.As part of the Encounter input process, we can ignore these, but we would like to remove them prior to encounter.
Any suggestions fort the best/easiest or recommended method for doing this?
Steven
  • grasshopper
    grasshopper over 14 years ago
    Hi Steven, can you elaborate on the modules you are referring to? Most of the module that RC introduced nd up removed in the end so curious what modules are creating problems and what kind of problems they are creating ? thanks, gh-
  • moogyd
    Sorry, I seem to have made a mistake. I was informed by the layout engineer (encounter) that there were empty modules, and we both assumed that they were present in the netlist from RTL Compiler to Encounter.
    Having checked, it seems that this is not the case, and that Encounter is somehow creating empty modules.
    We need to check why this is.
    Steven
