  2. Logic Design
  3. How to set_current_module in RTL Compiler??
  • Replies 10
  • Subscribers 62
  • Views 21178
archive over 19 years ago
Hi all,
I need to perform synthesis of a sub-block of the design. And then merge it with the top design.
I am using RTL Compiler.
In pks or build gates this was simple, we had the command set_current_module .. and one can then perform synthesis on a subdesign.
There seems to be no direct equivalent of set_current_module in RTL Compiler.
I found one command in RTL Comiler, derive_environment.
This promotes a subdesign to a topdesign.
So in design database we will now have
/designs/topdesign
/designs/subdesign_promoted_top
The synthesis which I perform on /designs/subdesign_promoted_top is now independent of actual topdesign.
This  works. But how can I later merge the
into
/designs/topdesign ??
I see no way to do this in the userguide!
Can someone help me?
Thanks in advance,
Pradeep
Originally posted in cdnusers.org by spveer
    Hi Pradeep,
    Try the following:
    edit_netlist new_instance -name /designs/subdesign_promoted_top /designs/topdesign
    There are more options for "edit_netlist new_instance" in the manual
    Max
    Originally posted in cdnusers.org by Stalker
    Sorry, tipo:
    edit_netlist new_instance -name SUBDESIGN_INST_NAME /designs/subdesign_promoted_top /designs/topdesign
    Thanks Stalker,
    I will try this tomorrow, when I am in office..
    But what should I do with the existing subdesign in the topdesign..?
    will that be overwritten?
    Or should I first remove the existing subdesign, and then create a new instance using the subdesign_promoted_top?
    Can you please tell me if possible, about how merging takes place...
    Pradeep
    You can continue working with you topdesign as usual, the only thing, that you can't omit the design name in the commands, for example:
    write_hdl topdesign > top.v
    and not
    write_hdl > top.v
    I don't know exactly how the new instance is linked, but I think the subdesign_promoted_top is needed for correct work.
    Hi Max,
    I tried using this...
    now on the topdesign I have an unconnected instance in the hierarchy,  called SUBDESIGN_INST_NAME
    If I try to optimize, since this instance is unconnected, and not driving any ports, the instance is removed by synthesis.
    I also tried the following:
    The hierarchy looks like this:
    /designs/topdesign/instances_hier/xxxx
    /designs/topdesign/instances_hier/subdesign  ----- this is promoted to subdesign_promoted_top
    /designs/topdesign/instances_hier/SUBDESIGN_INST_NAME  ---- this is subdesign_promoted_top copied back into topdesign
    now I removed subdesign
    rm /designs/topdesign/instances_hier/subdesign
    So the hierarchy now looks like this:
    then I have run 'synthesize'... But however the tool sees /designs/topdesign/instances_hier/SUBDESIGN_INST_NAME, not driving any ports and optimizes it away.... but doesnt link it to topdesign!! :(
    I am still not sure, how to link the designs....
    Hi Pradeep,
    have you tried the change_link command. I have used this in the past in a similar flow with pretty good success. I think the key is that the pin names have to match.
    gh-
    Originally posted in cdnusers.org by grasshopper
    Hi gh,
    yes,  change_link works...!
    i was just trying that and got ur mail too :)
    thanks n regards,
    pradeep
  • jojo57006
    jojo57006 over 12 years ago
    Me too I am trying to synthesize subdesigns because my vhdl code is too big. So, I need to put to a top-level every instance of my design and so on use the command derive_environment.
    Please can you help me to use this command. Where I write :
    rc :> derive_environment /designs/my_top_design/instances_hier/my_subdesign_to_put_to_top_level
    the terminal is block !!
    This command take a long time or there is a problem with it ?
  • grasshopper
    grasshopper over 12 years ago
    How big is  /designs/my_top_design/instances_hier/my_subdesign_to_put_to_top_level ?
    What exactly is your goal ? Can you describe what your flow is ?
    gh-
  • jojo57006
    My goal is to make the low power multi vdd synthesis of my design : design/top_rs232
    I have 200 000 gates to synthesize and I work on the server of my school. I can't make the synthesis directly because of this server so I want to elaborate all the design and synthesize each blocks separately. After I will read all the .v file and redo the synthesis which now the server can support.
