  2. Logic Design
  3. abort points
  • Subscribers 61
  • Views 18274
abort points
archive over 20 years ago
i'm running an rtl2gate verification and i'm running into abort point issues.  the gate level netlist has scan and clock gating inserted.  i'm running version 05.10-s200
i have the "set flatten model -gated_clock" switch set.
i've tried running a "compare effort high" run after the medium run.
i've tried "set compare option -part flow" (undocumented) with "compare effort low"
i've run out of ideas, and i can't find any documentation anywhere on how to deal with abort points.  the cone of logic doesn't seem to complicated: there are 3 DFFs and 1 PI feeding this cone.
i was able to verify the same design using synopsys formality.
Originally posted in cdnusers.org by crackoner
    Can you try 'analyze abort -verbose' and then 'analyze abort -compare' in release 6.1? (without -part flow)
    Chrystian Roy
    Conformal CoreComp AE
    Originally posted in cdnusers.org by croy
    chrystian,
    your suggestion resolved all the abort points i had. can i assume that it's not neccessary to run the "analzye abort -verbose" before the compare step?
    thanks for your help,
    crack
    Hi
    Correct. No need for 'analyze abort -verbose' if 'analyze abort -compare' did the trick.
    We're getting very good success with that command in 6.1.
    Chrystian
