  2. Logic Design
  3. Does test compaction reduces tester time or memory or both...
  • Subscribers 62
  • Views 15755
Does test compaction reduces tester time or memory or both?
vipul982
vipul982 over 13 years ago
  • bmiller
    bmiller over 13 years ago
     Please clarify if you are referring to hardware compression (hardware inserted into the chip to split long fullscan chains into shorter scan channels), or software compaction (ATPG technique to reduce pattern count).
     I guess the answer isn't that important, because both techniques will reduce both tester time and memory, although software compaction is not nearly effective as hardware compression logic.   Software compaction nearly "free", however, as it only consumes runtime.   The only other downside to software compaction is a possible increase in the power consumption of a pattern.
  • vipul982
    Hi, I got this cleared in the following link.
    http://www.linkedin.com/groupItem?view=&gid=1643367&type=member&item=200697375&qid=e3652c03-ddcb-468e-99ef-23f58e5ff074&trk=group_most_recent_rich-0-b-ttl&goback=%2Egmr_1643367
    Vipul
