  2. Logic Design
  3. difference between Random Resistance faults and deterministic...
  • Subscribers 62
  • Views 17593
difference between Random Resistance faults and deterministic faults?
vipul982
vipul982 over 13 years ago
what is random resistance faults? how different is it from the deterministic faults? why do we do the RRFA(random resistance fault analysis)?
  • bmiller
    bmiller over 13 years ago
     I suggest you read the "Test Point Insertion Application Note" on support.cadence.com.
     In general, Random Resistant Faults are those that are difficult to test with random stimulus.  Random Resistant test point insertion is used to decrease pattern count and test time.
    Determinisitic Test Point insertion is used to increase coverage.  It requires an ATPG experiment to be run, whereas Random Resistant analysis can be done before scan chains are inserted.  Deterministic Test Point Insertion is used to achieve very high 99+% coverage in critical applications.
